![]() | Home > Technical (L322) > Heater blowing cold (I doubt anyone else has had this fault) |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I have disconnected the coolant valves wiring ( As they remain open). This gives good heat flow with the Aux pump & Nothing above 1500 rpm. With the aux unplugged, the flow is minimal & low temperature, hence my next move. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
I've got a 2011 TDV8 but see no reason why this same issue couldn't occur on any other engines also.
That's interesting Gary. What was the issue with the compressor & did your air con work? |
The issue was the pressure release/control valve on the air con compressor.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
Does it instantly go cold when you go above 1500rpm, or does it fade to being cold.
Gary, my AC works perfectly, so can’t see the compressor being the cause ( although I may stand corrected).😄
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
How is it going with this 1 ?? I'm about to flush the heater matrix in my new to us D3 v8 the passenger side heat is almost non existent. Iv not read that you have tried this yet |
Hi Dave, I've left it alone at the moment, as I have some heat & awaiting a little warmer weather |
Well good luck with it they do try our patience |
UPDATE - Still the same after loads of work & parts. I thnk that it's defeted me |
You will be fine running no stat it will give full flow around the rad tho so not sure you will achieve what your looking for but nothing to loose. You will get full flow and leave the aux valves unplugged like you say
Only flushed with mains pressure, but had good flow. The heat at idle / low revs- speed is very good though.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
There’s nothing I can add to this other than to say it’s an incredibly unusual fault.
David, You are correct. It's one of the bottom hoses that feed coolant around the oil coolers (Oil mixer Control valve). I've changed that & bled it.
