![]() | Home > Technical (L405) > 3.0 TDV6 Crankshaft issue |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I found it interesting as well … The designers clearly had concerns about the design from the outset. Such a shame it would appear to have tarnished the reputation of the engine, as by all other accounts it’s a good unit and suited to the vehicles it goes in. V8 or else ... |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
Great Video Thanks 2018 SE SDV8 4.4 Byron Blue |
Delict Member Since: 25 Aug 2024 Location: Podhajska Posts: 1 ![]() ![]() |
This post has been edited by the site administration team PSA already had V6 transverse engine, and used it succesfully for years. 3.0i XFU, 211hp ES9J4S with no mechanical problems. There was even an tuning option from carlsson with 233hp. Please take a look at the crankshaft part nr 0501.J2. The crankshaft is 4x seated in engine block. The deal between FORD and PSA was this :: PSA gave reliable 1.6, 2.0 and 2.2HDi engines and got unreliable V6, because they never had any V6 diesel. 8 FORD made it by cutting the bigger AJD V8 diesel, just look at the crankshaft, its the same. Its nice you want to blame PSA, but no, LR always had problematic engines. Starting with head cracking TD5 and ending with TDV/SDV6. 3.0 HDi ended with Peugeot 407 (2011) and Citroen C5 (2016), and they never exceeded 241hp and 450Nm. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Well I’m on my 4th V8 Diesel - no issues whatsoever with the engine, no oil dilution and no DPF issues at all. We’ve also had several Discovery TD5’s from new - again no issues whatsoever. The only RR engine I have had issues with was the VM diesel fitted to the classics - again bought new and serviced by LR. Other members of the family have had failures with the V6 Diesel - again MD serviced. That’s my experience and I’m on my 17th RR. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 194 ![]() ![]() ![]() |
Having owned Landrovers in the past the VM diesel was my first experience of Range Rovers. I was told by my local Indie that they were basically a marine engine and the nearer to the sea bed the better. Seriously though it was a powerful and reasonably quiet engine, when it was running. When I got bored with pieces flying off it and constant challenges I replaced it with a 300 Tdi. Had 4 FFs since but I still look back with affection on the Tdi. 250k miles and never a broken crankshaft.🤔 |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 36 ![]() ![]() |
There’s a ton of reasons to change the oil at 5k miles/8k Km.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 180 ![]() ![]() ![]() |
I am running 5W40 C3 oil in my TDV6 and changing every 6k miles / 6 months whichever occurs first. I know there are plenty or views on the 5W30 v 5W40 debate but after looking in detail at the argument that was my conclusion. The proof will be in the pudding as to whether my engine lasts longer, doesn’t suffer crank failure (although that is still not proof it was all due to the oil choice).
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 156 ![]() ![]() |
The tdv6 being used in the Volkswagen Amarok is still snapping cranks. So not enough to solve it! |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
I'm curious, Why would any manufacturer recommend the "wrong" oil? |
It is not so much the ‘wrong oil’ but one that is designed to achieve fuel efficiency targets but potentially at the cost of engine longevity.
A few reasons. The oil they specified is an older certification for one. C1 is going to be harder to find. C1 is a bit less SAPS than a C3, so probably safer for DPF on LR’s ridiculously long OCI. Change it at 5k and a smidge extra SAPS shouldn’t matter. Their long OCI is due to hitting ownership cost benchmarks. Marketing. |
That’s interesting and makes sense |
and yes fuel economy is likely a reason too. |
Here's another one!
