Home > Maintenance & Mods (L322) > Stainless steel engine bay
Rudyard1
I have searched for a while now! Another member posted about how they had swapped bolts/screws in the engine bay for stainless steel versions. Does anyone know where I can find their post?!
Post #655906 7th Feb 2023 11:54am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i think that was me new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #655909 7th Feb 2023 12:03pm
Rudyard1
Brilliant stuff! Do you have any info on sizes required? Or any pics to share Oggy? Would be appreciated!
Post #655913 7th Feb 2023 12:56pm
oggy
if you go on my profile about page 17/18 ish look for replaced all bolts on the slam panel today some pictures there . use A4 bit better quality stainless wear ever I go I replace it with stainless steel wheel arches . rear tailgate. engine bay . most are 6mm /8 mm bolts and nuts . washers are the same 6/8 some 22mm some penny size. some are special machine bolts for the rear tailgate. replace the ones where the tailgate straps fit . spray around the area where the washer is going to be with some clear wax protector before doing up. i got mine from a firm called kays fasteners on eBay spot on firm and good service. i did have loads over from when I did a couple or 4 boat builds. must say looks so much better new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #655919 7th Feb 2023 1:59pm
Rudyard1
Thanks - that’s a big help!
Post #655926 7th Feb 2023 2:54pm
Page 11 and 12 here... some pics...
https://www.fullfatrr.com/forum/topic55541.html Pete
-Click here for Thread-
Post #655966 7th Feb 2023 8:58pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
More direct link for you Thumbs Up
https://www.fullfatrr.com/forum/post585959.html#585959 FFRR SDV8 Autobiography
Post #656003 8th Feb 2023 8:49am
Bingo_123
hi Oggy, which screws(size/dia) did you use for the airbox, if possible please share a link. thanks
Post #656115 9th Feb 2023 2:19pm
oggy
okay bingo i will have a look and take a picture and the size cars up at the workshop will be going up tomorrow new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656117 9th Feb 2023 2:24pm
Floopy
From experience with swapping bolts to stainless make sure they are free from burrs and consider using lubricant during assembly as stainless bolts can be prone to galling (cold welding).
Be especially careful in aluminium parts too as a friend of mine found out after swapping the exhaust studs on his freshly rebuilt cylinder head for stainless steel and using stainless nuts instead of brass. The nuts seized and the studs welded themselves in the head just enough to tear all the softer aluminium threads out.
That said, done carefully they can really improve an engine bay and make future work much easier. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
2008 L322 Vogue SE 4.2 S/C
Post #656118 9th Feb 2023 2:40pm
oggy
hi bingo the screws for the air box are 30mm x 4mm did not go up last week so went today the reason why late getting back new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656496 13th Feb 2023 5:18pm
