Home > Maintenance & Mods (L322) > Stainless steel engine bay |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
i think that was me new vehicle purchase
7th Feb 2023 12:03pm |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 63 |
Brilliant stuff! Do you have any info on sizes required? Or any pics to share Oggy? Would be appreciated! |
7th Feb 2023 12:56pm |
if you go on my profile about page 17/18 ish look for replaced all bolts on the slam panel today some pictures there . use A4 bit better quality stainless wear ever I go I replace it with stainless steel wheel arches . rear tailgate. engine bay . most are 6mm /8 mm bolts and nuts . washers are the same 6/8 some 22mm some penny size. some are special machine bolts for the rear tailgate. replace the ones where the tailgate straps fit . spray around the area where the washer is going to be with some clear wax protector before doing up. i got mine from a firm called kays fasteners on eBay spot on firm and good service. i did have loads over from when I did a couple or 4 boat builds. must say looks so much better new vehicle purchase
7th Feb 2023 1:59pm |
Thanks - that’s a big help! |
7th Feb 2023 2:54pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
Page 11 and 12 here... some pics...
7th Feb 2023 8:58pm |
James W Member Since: 29 Nov 2009 Location: Wirral Posts: 284 |
More direct link for you
8th Feb 2023 8:49am |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
hi Oggy, which screws(size/dia) did you use for the airbox, if possible please share a link. thanks |
9th Feb 2023 2:19pm |
okay bingo i will have a look and take a picture and the size cars up at the workshop will be going up tomorrow new vehicle purchase
9th Feb 2023 2:24pm |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 73 |
From experience with swapping bolts to stainless make sure they are free from burrs and consider using lubricant during assembly as stainless bolts can be prone to galling (cold welding).
9th Feb 2023 2:40pm |
hi bingo the screws for the air box are 30mm x 4mm did not go up last week so went today the reason why late getting back new vehicle purchase
13th Feb 2023 5:18pm |
