Home > Technical (L322) > TDV8 2012 Westminster clicking noise near to radiator
Page 3 of 3 <123
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Both of ours do it, decided to ignore it. You can't hear it from inside so it doesn't bother me. No idea what it is though. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #538901 30th Dec 2019 11:55am
Cycle the gearbox into different modes to see if it changes the noise. Nothing in the transfer box should be moving with the vehicle stationary, sounds louder at the back of the engine to me from the vid, but can’t think of anything which should be rotating there apart from the TC at idle....
At that sort of frequency, it’s roughly the action of 1 cylinder, it may be worth running some injector cleaner through the system in case there is a slightly sticky/noisy injector. My money would be more likely something like that. If you can get the cover off the engine and use a listening rod you may be able to narrow down where it is coming from, being very careful of the rotating parts obviously...... There is nothing that can't be fixed with a hammer😜😜
Post #538946 30th Dec 2019 7:12pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Re: TDV8 2012 Westminster clicking noise near to radiator
London Rangie wrote:
I have just spent £700+ having the belts and tensioners renewed but the clicking noise is still there when the engine is cold. It goes away when warm. Any ideas please?
https://youtu.be/OjrKWEiBINA
....... and apologies that the video is a shot of my foot!
Well it sems mine is making the same noise now. Did anyone ever get to the root cause of this issue?
Same as the video on youtube in the original post. Only lasts about 30 seconds or so and then disappears, Once eninge stopped takes at least 10 hours of being swiched off before it will make the noise again when renigne is started.
EDIT:
FBH does not make this noise,
Only does it when engine is running , for the irst 30 seconds or so when cold.
Have turned AC off and it still does it.
Tickin does change frequency when engine is revved.
Is too slow to be an injector.
Noise is from front of engine, most noticeable on front upper left hand side when facing the engine.
Idlers and belts changed 15K miles ago with the alternator.
Thanks
Thanks
Post #656236 10th Feb 2023 9:16pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
It's the viscous fan making the metallic clicking sound. Had the exact same noise on my 4.2 supercharged, once warm the clicking stopped. Replaced the viscous fan coupling (came with a new plastic fan) and the problem went.
Post #656240 10th Feb 2023 9:30pm
neilly
Thanks, I will have a look at that tomorrow.
Hopefully a nice easy fix.
Thanks.
Post #656241 10th Feb 2023 9:34pm
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi Neilly, did you replace the viscous fan and cure the clicking? Wife just informed me this morning that mine has started clicking, couldn’t hear it from inside though. Again only lasted 30 seconds ish.
Cheers 2011 4.4 TDV8 Autobiography Ipanema sand
2007 3.6 TDV8 RRS HSE Black
2003 4.6is V8 BMW X5 Black
2000 2.5 TD5 Discovery Blue
2000 1.8 Freelander Black
Post #675506 13th Oct 2023 8:00pm
neilly
Hi Yellopin,
Yes the fan was replaced and the clicking stopped. So hopefully it stays away..LOL. has been 4 months now and no noise.
Cheers
Post #675510 13th Oct 2023 8:43pm
Yellopin
Brill, thanks Neilly. Looks like they are a single piece assembly and coupling can’t be removed/replaced from the fan? Oh well, another little job to play with. Although many report it’s just another one of those 4.4 idiosyncrasies that “they all do that”, I don’t think I could live with that clicking if I know it’s there even if I can’t hear it from inside. 2011 4.4 TDV8 Autobiography Ipanema sand
Post #675512 13th Oct 2023 8:57pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Yeah mine started doing this when the weather cooled five years ago when I first purchased her... but always stops once engine is up to operating temp - and it never (well rarely) happens in summer. I recall somewhere reading/seeing that some owners had changed the viscous couplin/g unit and the problem was still there after replacement - so I never touched the thing. My 2012 TDV8 (70,000 miles) seems OK if a tad clicky clicky 'still' over five years later...
But my quite recent full service (had a known trusted mobile guy do it before my very own eyes on drive) of diffs, transfer box, remove all air box units to clean out and replace all screw fixings and both filters, engine oil and filter plus fuel and cabin filters and a complete clean up of lying codes and complete vehicle checks etc) had her running like an absolute dream (oooooooh so smooth) and she ran quite superbly even before. The viscous couplin/g clicky clicky noise has not been heard yet - but I'm sure the colder weather (solar minimum period remember Shocked ) will have it return, no doubt...
LR and RR establishments used over the past five years (last one a year ago) seem never to have even opened up the turbo filter boxes once, as the filter box screws were all seized, and the turbo one filter was certainly more than a year old (only about 2000-miles travelled since) and was probably possibly five years old or so (25,000-miles done since) and each time I had particularly asked for all these filters to be replaced!!! Which I don't think they EVER did... I reckon they could not be assed to try to sort the seized screws... And all my recent service was done in under three hours - including an attempt at getting the rear hatch wash wiper spray working again...
NO more LR RR extortionist blaggers for me, mates.
Post #675608 16th Oct 2023 7:30am
DrRob
New type of air box screw Thumbs Up
https://www.advancedfactors.co.uk/adv8796-...3630-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #675613 16th Oct 2023 8:11am
Page 3 of 3 <123
