Home > Technical (L405) > No start problem
FR motors
Austria 2016 Range Rover Vogue SDV8 Farallon Black
No start problem
Hello
I rebuilded 4.4l diesel engine now it doesent start... Injector not working.
So I gave my injectors to test and rebuild all 8 of them. Also they Got New codes. Now i have two questions...do I have injectors fuse Somewhere)? (cant find it)?
I didnt recode my injectors on ecu... Do you think that this can be cause of not start.
I get code p060a internal prcessor managment.
Thank you
Post #656285 11th Feb 2023 5:38pm
Phoenix
Check the engine control module for moisture on the connectors, the injectors not triggering indicate a fundamental issue, not a problem with the injectors themselves. Are the crank & camshaft position sensors connected and giving an output? There isn't an injector 'fuse' as such, but there are several power supplies to the control module, along with several ground connections. you need to check these using the appropriate wiring diagram.
Post #656299 11th Feb 2023 7:21pm
FR motors
Thank you for your Quick replay.... I cant find any wiring diagram for that car maybe you can point me Somewhere? (link).
Ill check crank sensor and camshaft sensor But problem IS there Us no pinout to find on internet for that car Sad help
Post #656304 11th Feb 2023 7:41pm
Phoenix
Can't help with the wiring diagam but you can buy a day's access to Topix for a single VIN quite cheaply, and spend the 24hrs downloading everything for that vehicle you could possibly need...
https://topix.landrover.jlrext.com/topix/p...createForm
Post #656309 11th Feb 2023 8:35pm
FR motors
So I maniged to clear code p060a But now i get code U0447-00(getaway module A invalid data recived) and still no pressure after injector pump.
Do anyone know what module A is?
I have no other codes Sad
Starting to lose hope.
Can someone Just give me some direction where to start.
Post #656440 13th Feb 2023 10:44am
This any help, but I think you may need a good auto electrician... Thumbs Up
https://f01.justanswer.com/DanielL811/d63f...47_Jag.pdf Pete
-Click here for Thread-
Post #656457 13th Feb 2023 1:03pm
FR motors
Can secondary battery giving me trouble for starting the car?
Post #656458 13th Feb 2023 1:18pm
no, but check that the primary battery is ok. ... - .- -.
Post #656460 13th Feb 2023 1:26pm
FR motors
PriMary battery IS New also took ecu out for 1h
Still no start
Going crazy with this car 😑
Gonna solve that code and then let see.
If not I have no idea where to go on.
Post #656461 13th Feb 2023 1:31pm
Phoenix
Look at actual values for fuel pressure (high & low), crank & camshaft sensors and MAF/ Charge air sensors, both static and cranking, they should give you a better idea of what is happening - or not, with your failure to start issue.
Post #656488 13th Feb 2023 4:34pm
FR motors
Ok I Got rid of u0447-00 it was second battery. Now car cranks much better But now i have code P062E-11 fuel injector driver circuit performance bank 2.
Also I have a conector on loom(driver side) front bumper that I dont know where it goes. Help please
[url]
[/url]
Post #656562 14th Feb 2023 11:13am
FR motors
So I Got someone with high end tester to my range
There are two fault that are changing once IS P026e and P026d both are injection circuit -(ground connection fault).
Live sata from both sensors cam and crank good.
What IS my next step?
Post #656594 14th Feb 2023 3:03pm
Phoenix
Test all the injectors & wiring as per the following, pay particular attention to the harness being shorted to ground or mutual shorts.
Although only injectors 1-4 are mentioned, you need to test all eight - and the wiring to them.
Post #656633 14th Feb 2023 7:15pm
