![]() | Home > Technical (L322) > Air Suspension 2011 |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Probably best to investigate for leaks in the, system first, most likely nothing wrong with the compressor... |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Have the diag, states no leak but intermittent fault on compressor, so wonder if it is in that were the issue is. Going to put it up to full height this weekend and soapy water time to check. If nothing is found, on the bags and i do replace the compressor, does anyone know if it would need coding to the car? |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Replacing compressor like-for-like requires no coding.
