Home > Technical (L322) > Air Suspension 2011
SinbadRose
Air Suspension 2011
Hi all, So the front corner dropped a little, but went back up when the car started, while driving i got suspension raising a couple of times (air going in) and then a pump over heating warning.
Had a diag done on it, it stayed up for 30 mins with no loss, and they state its the compressor at fault from the diag. Does a new one need to be programmed to the car, or can a new full unit be put in without issue?
Thanks for any info
Post #656860 16th Feb 2023 3:54pm
dingg1
Probably best to investigate for leaks in the, system first, most likely nothing wrong with the compressor...
Post #656865 16th Feb 2023 4:52pm
SinbadRose
Have the diag, states no leak but intermittent fault on compressor, so wonder if it is in that were the issue is. Going to put it up to full height this weekend and soapy water time to check. If nothing is found, on the bags and i do replace the compressor, does anyone know if it would need coding to the car?
Post #656947 17th Feb 2023 3:39pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Replacing compressor like-for-like requires no coding.
If changing from Hitachi to AMK, there is a change to be made to the car configuration. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #656960 17th Feb 2023 5:27pm
