![]() | Home > Technical (L405) > Aftermath of a misfuelling... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
SDV8 recovered in recently, as a non start
That is your last line of defence against bits of the HP fuel pump getting into the cylinder bore and scoring them...
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
Great diagnosis and explanation. Hunt for a L405 is on. |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
As above, thanks Chris
That is the end of the fuel rail PRV |
FWIW, this is what was drained from the tank
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
I'm going to go out on a limb and suggest a backyard attempt at washing red diesel gone wrong. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Customer has said it was supplied by a reputable retailer. Clearly it isn't |
Could it be the 2 stroke oil mixture? Hunt for a L405 is on. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Is the engine |
Not sure if serious or sarcastic ![]() This was, apparently, white diesel, delivered directly from a nationwide fuel supplier. Clearly something has gone wrong someplace |
Sorry I was being serious thinking perhaps someone's been experimenting. Hunt for a L405 is on. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
I thought the same - someone trying a Kerosene/2 stroke mix? |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
That is nuts, someone spending tens of thousands on a modern motor and scrimping on fuel.
