![]() | Home > Technical (L322) > Restricted performance Gearbox |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 ![]() ![]() ![]() |
I had some remedial work to do on my car after an MOT fail, I renewed both lower control
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8813 ![]() ![]() ![]() |
Have you got odd sized tyres across an axle or have you changed the tyre size in the IID settings..? Pete
Hi
OK, I had that fault code on my old Rangie.. those two reasons can set that fault...
Had a play with the iid and found the wheel speeds in the abs module, they are all reading correctly.
Screen grab all the codes, clear them and keep your fingers crossed...
The car is still doing it, driving along car loses drive revs rise and if you rev it up there is a screeching
Just an update, this turned out to be the transfer case and
Glad you got it fixed... |
