![]() | Home > Technical (L322) > Front left height sensor loom |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2740 ![]() ![]() |
The wires from the suspension sensor to connector pair C2411/12 are 2.7m long which at a guess puts the connectors behind the LF footwelll side cover. The wires from the connector pair to the suspension ecu are 6.8m long.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
hmm i can check that harness tbf but the issues started when i replaced the 2 front left/right struts.
Is it a suspenion fault or an adaptive dynamics fault or both?
It's both, car does have adaptive suspension. I'll be stripping down my repair and checking tomorrow.
The ebay one might only be a single sensor for height control on earlier non-CVD vehicles rather than a double one that's required for CVDs. |
i checked tbf, had all the pins and it tbf does claim to be CVD one. i think to eliminate that issue ama just order a LR Its actually a sport |
joejoe300 Member Since: 22 Dec 2024 Location: Nottinghamshire Posts: 13 ![]() ![]() ![]() |
Hi did you get to the bottom of your issue |
take a picture of your sensor, theres a specific way they are installed.
Its mounted with the arm facing out |
