Home > Technical (L322) > Front left height sensor loom
mgrover
I know you can get a replacement loom and cut the wires and crimp/solder
I did that tbf, went as high up as possible but I still got the faults and now a new one has turned up about circuit voltage out of range so odds are the soldering has failed somewhere in my repair.
But my real question is, do those wires track back to a connector somewhere so I can replace the entire loom? Since replacing it didn't fix the initial suspension/adaptive fault I was having Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #658295 2nd Mar 2023 10:54pm
GraemeS
Australia
The wires from the suspension sensor to connector pair C2411/12 are 2.7m long which at a guess puts the connectors behind the LF footwelll side cover. The wires from the connector pair to the suspension ecu are 6.8m long.
Have you checked for damaged wiring under the RH rear seat? A harness there tends to take a short-cut then get squashed by the seat frame.
Post #658306 3rd Mar 2023 5:15am
mgrover
hmm i can check that harness tbf but the issues started when i replaced the 2 front left/right struts.
I assumed I must have damaged the height sensor loom.
Is there a way I can test the pins at the height sensor connector with a multimeter to see which is the broken wire? Its actually a sport Sad
Post #658314 3rd Mar 2023 9:28am
GraemeS
Australia
Is it a suspenion fault or an adaptive dynamics fault or both?
These vehicles use a twin heght sensor, 1 for suspenison height and the other for adaptive dynamics, with 3 wires each. The wiring diagrams are below.
https://www.fullfatrr.com/gallery/albums/u...sion~0.pdf
https://www.fullfatrr.com/gallery/albums/userpics/15719/CVD~1.pdf
Post #658319 3rd Mar 2023 10:47am
mgrover
It's both, car does have adaptive suspension. I'll be stripping down my repair and checking tomorrow.
I did snag the height sensor wire when I was doing the strut changes so defo thought that was it.
I also did repair the wires going to the top of the struts, that fixed a diff issue.
Also replaced the height sensor, albeit with an ebay special
https://www.ebay.co.uk/itm/403472337893
Might be tempted to just order an oem one and be done with it. Its actually a sport Sad
Post #658320 3rd Mar 2023 10:51am
GraemeS
Australia
The ebay one might only be a single sensor for height control on earlier non-CVD vehicles rather than a double one that's required for CVDs.
Post #658376 3rd Mar 2023 8:39pm
mgrover
i checked tbf, had all the pins and it tbf does claim to be CVD one. i think to eliminate that issue ama just order a LR Its actually a sport Sad
Post #658377 3rd Mar 2023 8:39pm
mgrover
Censored fixed.
the error codes were correct.
the sensor was point inwards instead of outwards. i compared it to the right sensor alignment and there it is.
am guessing it got "crossed" over when I dropped the hub.
codes related because Google doesnt have much
C1A03-21
C1A03-78 Its actually a sport Sad
Post #660123 23rd Mar 2023 2:03pm
joejoe300
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Fuji White
Hi did you get to the bottom of your issue
Post #707418 22nd Dec 2024 12:42pm
mgrover
take a picture of your sensor, theres a specific way they are installed.
i installed mine backwards and its incorrect. Its actually a sport Sad
Post #707422 22nd Dec 2024 1:05pm
joejoe300
Its mounted with the arm facing out
Post #707423 22nd Dec 2024 1:09pm
