Home > Maintenance & Mods (L322) > SC 5.0 Brembo Brake Bleeding
There is a specific sequence to pressure bleed in the WM..
I've had no issues with gravity bleeding when just changing callipers though. There shouldn't be any air in lines, just an empty calliper... Thumbs Up Pete
-Click here for Thread-
Post #658524 5th Mar 2023 12:13pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Brake bleeding
Hi JayGee
Any pressure kit you would recommend? Some advertised for £30 - £45.
I would also advise freeing the brake nipples in-between brake flushing period and bleeding. A new caliper costing £1000 alone if needed. Fortunately my local garage got one nipple out and replaced for me for a £100 plus the cost of brake flush he did.
Dave
Post #658527 5th Mar 2023 12:52pm
JayGee
I can't recommend a particular model but just avoid the cheap ones that use you spare tyre as a pressure source. If you have an air compressor in your workshop there are good ones that can use this. 2012 TDV8 Vogue (L322)
Post #658530 5th Mar 2023 1:30pm
Nylands
Thanks JayGee :thumbs up
Post #658538 5th Mar 2023 4:42pm
Gremlin500
I got one of these:
https://www.lasertools.co.uk/Product/4832/...Bleeder-2L
Screwfix used to stock it much cheaper, I also got the method wrong, so it might have worked much better, had I done it right Embarassed I changed all 4 hoses. (and calipers), so probs lost a lot of fluid even though I clamped the hoses, when you disconnect them, there is no way to stop air getting in.
More in this thread:
https://www.fullfatrr.com/forum/topic63843.html
Make sure air can easily get out of your collector jar, -that was my mistake, and reduced the flow significantly, being paranoid about not wanting brake fluid all over my driveway! Embarassed Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #658540 5th Mar 2023 4:58pm
Gremlin500
JayGee wrote:
AFAIK the GAP has an ABS purge function but not sure if this is the same as a full brake bleed function. The main issue for most will also be the fact that the bleed nipples will be galvanicaly seized in the calliper body so bleeding the brakes will be impossible anyway.
At the risk of opening a whole new can of worms (which I’m good at) Embarassed I VERY CAREFULLY AND NEATLY wrapped the nipple threads in PTFE tape, to act as a physical barrier between the dissimilar metals rather than to seal anything.
The threads are outboard of the sealing cone, so the PTFE shouldn’t be able to get into the brake fluid anyway.
You have to be careful only to tape the threads and nothing more.
Has it worked? Dunno, maybe I’ll find out in a few years’ time Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #658541 5th Mar 2023 5:12pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
They all opened albeit with a bit of a creak. Front ofs outboard didn’t have any flow so I’ll get a new nipple for that one. Although I might take it out and try and poke a bit of wire in it to see if there’s just a blockage. Pedal better but I suspect will be even better with that 4th nipple bled properly Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658551 5th Mar 2023 6:09pm
Gremlin500
@goldstar,
Given the low cost, I ‘d just replace all the nipples with new as a matter of course.
There are nipples made out of various materials available, but I can’t vouch for them, I’ve got the standard ones myself.
Even if you used stainless, its still two dissimilar metals. V6 Vogue - “Less is More” - less to go wrong!
Post #658552 5th Mar 2023 6:23pm
Goldstar
You’re absolutely right and I did just that about 10 mins ago. 👍 Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658553 5th Mar 2023 6:29pm
Use this stuff, it will sort your nipples out.... Shocked
Seriously it is excellent, especially for our salt laden roads... Thumbs Up
https://www.amazon.co.uk/Unknown-Tef-Gel-1...amp;sr=8-1 Pete
Post #658560 5th Mar 2023 7:10pm
pcourtney
I can agree 100% - I got two 56g tubs, have used it on all our cars for bleed nipples and also used it sparingly on wheel studs ( the passenger side wheel nuts get a lot of exposure to our salty roads in the winter and now no rust on them, well the six cars I have looked at anyways) AMAZING STUFF !
Post #697267 2nd Aug 2024 4:54pm
