Home > Maintenance & Mods (L405) > L405 Park brake fault (Yellow light) |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
Well I've just had my third parking break actuator fail (that said I'm on over 190,000 miles so not too bad I suppose). Luckily happened at home and I managed an easy DIY fix as follows:
7th Oct 2023 11:57am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
^^^ I did exactly this a while back.
7th Oct 2023 1:13pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 74 |
I'm a bit late to the party on this one.
7th Oct 2023 2:06pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Chris, I don’t think you should have used copper grease? It’s mineral based and may denature the rubber O-ring seal:
7th Oct 2023 2:36pm |
Ditto, use Loctite sparingly and keep off rubber & plastic parts, it WILL make a mess of rubber in short order. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
7th Oct 2023 2:38pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Copper grease is the worst possible to use - you're just adding another metal into the mix...
7th Oct 2023 2:50pm |
All very useful to know! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
7th Oct 2023 4:53pm |
Mac35 Member Since: 26 Dec 2023 Location: Angus Posts: 13 |
Has anyone had a resolution to the issue when a new actuator didn’t fix the issue?
19th Jan 2024 4:59pm |
Well I had a twist to the usual problem. Fitted a new brake actuator only for it to fail within a month or so (or so I thought). The replacement didn't work either and on investigation I found that the splined shaft in the caliper had worn to the extent that the actuator was able to spin without moving the brake. A replacement caliper fixed this. At least I have a spare actuator "in stock" now. |
14th Mar 2024 3:26pm |
