Home > Maintenance & Mods (L322) > 4.4 TDV8 Top coolant pipe snapped the other connector… |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
I finally managed to get around to tackling the engine squeal I’ve had for far too long…
25th Feb 2023 1:54pm |
So I am a little closer to what i need.
25th Feb 2023 5:23pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
I think you'll find the whole assembly needs to be purchased (8592A), that's what I did for mine.
25th Feb 2023 5:55pm |
Cheers guys for the feedback. Indeed the assembly unit doesn’t appear to be available. Very frustrating.
25th Feb 2023 6:12pm |
Something along these lines if the hose sizes are correct.
Cheers for that rjff
25th Feb 2023 6:39pm |
Just spotted that 9.89 is printed on my current connector which is the same as your link
25th Feb 2023 6:44pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2695 |
Bit of brass or Ali tube and some jubilee clips would seem to be a practical replacement for that bit of plastic 2012 TDV8 Vogue (L322) |
25th Feb 2023 6:47pm |
I hope that works, if it does great. Let us know. Cheers
25th Feb 2023 8:21pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i had the same issue and replced it with this
26th Feb 2023 12:45pm |
As requested (albeit later than intended) the replacement clip worked perfectly! The only minor difference is the double disc of the original (which clips into a bracket) vs the single disc of the new one… but if you leave a slight gap where the hose meets the disc it slips into the bracket. All in all a quick and cheap replacement This…
Vs this… Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
6th Mar 2023 6:53pm |
Cheers jayk69. Another simple fix, however I prefer the flip method I used simply to allow me to remove the top pipe without issue in the future. Especially if the plastic get brittle over time and decides to snap when needing to separate it! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
6th Mar 2023 6:58pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
im pretty sure I've seen this part used by others... check actual sizes, i guessed 1/4 pcl... its common on car workshop airlines. and easy to buy on eBay too. you screw in the male to the main body, and warm the plastic pipe and slide over the other end
7th Mar 2023 2:09pm |
