Home > In Car Electronics (L322) > L322 2007 Android Headunit Options
Page 4 of 5 <12345>
Floopy
Does the Navtool work with the RSE? I'd quite like to be able to steam Youtube/BBC iPlayer etc. to the rear screens 2006 L322 Vogue SE 4.2 S/C (no longer owned)
2008 L322 Vogue SE 4.2 S/C
Post #656092 9th Feb 2023 12:00pm
mgrover
a few tips for the next installer
The power cable for the chinese android head units goes to the head unit under the glove box.
also you have to have the cd changer plugged in or a fibre optic loop back otherwise it breaks the loop.
after I did those 2 things, boom she sparked into life.
[/img] Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #656096 9th Feb 2023 12:20pm
KZ
Canada 2011 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Hey mgrover I am planning to purchase the same head unit as you installed and was hoping that I could trouble you for some more info about it.
1. Can you confirm size and resolution of the display? Is it actually 12.3" since most other displays of this size are floating forward of the dash. I like this one more if it is true. Also is the resolution 1920X720 and not 1024X768 or something.
2. Is there anything that does not function and does the clock setting enable setting the vehicles clock. And is there a display of 4x4 info at all?
3. Can one change the background image or perhaps run a custom launcher rather than the provided look?
4. If I could trouble you for a few pictures of the system on different pages such as radio, google maps radio or playing an music file etc.
Hopefully that's not asking for too much but I would really appreciate it.
Post #658813 7th Mar 2023 10:48pm
mgrover
I can check that next time I am in the car. I know which ones your on about but this is 12.3 i think because it gets rid of the bezels.
Setting the clock works fine, both the dash clock and the analogue one.
There is no 4x4 info at all.
There are other "car" settings, like mpg, rpm, temp etc etc, and some settings like C/F your supposed to be able to change. but they don't change at all.
One thing that doesn't work is remapping the setting wheel controls. I want one button to be set as the BACK button, but havent made it work via their app.
Yes, I installed Nova launcher, not a fan of their launcher.
Sure. Its actually a sport Sad
Post #658840 8th Mar 2023 9:39am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Are you sure you can set clock and date from android unit? All sellers says it is not possible.
Post #658846 8th Mar 2023 10:15am
mgrover
Yep, they mirror the android unit. Happy to try to make a vid.
Edit:
heres the vid, answers all the questions you could want really.
https://photos.app.goo.gl/hoD7UiBAM8ZaUgCt6 Its actually a sport Sad
Post #658847 8th Mar 2023 10:17am
jimmie
and this is really good information 😀
Post #658851 8th Mar 2023 11:02am
KZ
Thanks for the info.
I am guessing the 4x4 info and other settings can still be accessed and adjusted via the dash gauge display anyhow. Hopefully that didn't change.
The steering wheel controls operate but can't be changed?
If so I have a similar setup in my jeep and it doesn't respond to the system software. I believe the module that enables the steering wheel controls may be hard coded . I always meant to see if there was a steering wheel control adapter which could be added to enable both short and long press programming of the buttons.
A few other things I thought I should ask:
How is the phone call clarity?
Does the head deck retain the trim pieces to the left and right of the display? or would one need to paint the sides of the adapter black? (in my case the trim is piano black)
Thanks mgrover!
PS just watched the video excellent....the head deck looks like a good bet to me.
Post #658852 8th Mar 2023 11:18am
mgrover
Yes via the dash is fine, when you put it in offroad mode or whatever you can enable that mode where the dash changes to off road mode.
For me it's good, I installed the mic on the steering wheel, which btw is 2.5mm and the head unit port is 3.5mm so you need an adapter. Or am I remembering my BMW cause I did both very close together.
No it doesn't, I have a similar problem, they need to be painted piano black. I opted to just leave it tbf, laziness and all.
One thing I did notice is there is the amp hum. Now you can tweak the little device ground it comes with to try and negate that but you can still hear it, but once the car is started you never notice it tbh. Its actually a sport Sad
Post #658853 8th Mar 2023 11:26am
Urotex
United States 2007 Range Rover HSE 4.4 V8 Buckingham Blue
https://www.aliexpress.us/item/32568047746...DDNiEXyCbS
I see these android units on Aliepress with the AC module as well.
Has anyone installed one and if so, do most or all the stock functions work?
Thinking about upgrading my 2007 HSE
Post #663411 4th May 2023 12:32pm
Urotex
Post #663412 4th May 2023 12:33pm
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
That is an interesting piece of kit; I've already added Android Auto/Carplay into my 2010 but this intrigues me!
Post #663422 4th May 2023 3:46pm
jimmie
maybe some day. when they add support for original screens and change graphics to corrected l322
Post #663473 4th May 2023 10:00pm
Urotex
Here's one with the FFRR
Post #663476 4th May 2023 11:32pm
jimmie
but still wrong one...
Post #663572 6th May 2023 4:03pm
Page 4 of 5 <12345>
