![]() | Home > Maintenance & Mods (L322) > Deployable Side Steps Dead |
What about the red/green? That should have a battery positive supply (from fuse 49, CJB) The white although showing live all the time, will switch off once the infotainment shuts down. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
Yep, getting battery voltage on the red/green with the ignition off too.
So the big question, are these getting anywhere near the sidestep control module? |
I’m not even sure where they should go.
Right, I've done some more metering out of this loom tonight and now I'm really confused!
That is very strange and completely against the principles of control/switching segregation!
Thanks Phoenix.
I still think you should check pingrip at the control module, if, as it seems, the module is powered by the 'heavy' wiring, then (with the harness disconnected from the AHU) you should see CAN voltage at the AHU connectors - that will prove, in the absence of 'scoping the signal, that the module is powered up and capable of communicating as well as good pingrip on the power & CAN lines.
Here’s the ECU.
Bit more testing today.
I’ve taped the loom back up with fabric tape and refitted it to the car this afternoon.
Have also just done the following:
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 957 ![]() ![]() |
Got to admire your persistence David |
The CAN to the AHU essentially comes from the instrument pack, which is a bridge to the PATS module (most likely source of door open/closed data) and also a gateway between the MS-CAN & HS-CAN.
