|  | Home > Maintenance & Mods (L322) > Deployable Side Steps Dead |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | What about the red/green? That should have a battery positive supply (from fuse 49, CJB) The white although showing live all the time, will switch off once the infotainment shuts down. | ||
|  8th Mar 2023 3:16pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Yep, getting battery voltage on the red/green with the ignition off too.
|  8th Mar 2023 4:59pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | So the big question, are these getting anywhere near the sidestep control module? | ||
|  8th Mar 2023 5:24pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I’m not even sure where they should go.
|  8th Mar 2023 5:30pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Right, I've done some more metering out of this loom tonight and now I'm really confused!
|  8th Mar 2023 7:45pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | That is very strange and completely against the principles of control/switching segregation!
|  8th Mar 2023 8:44pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Thanks Phoenix.
|  8th Mar 2023 8:57pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | I still think you should check pingrip at the control module, if, as it seems, the module is powered by the 'heavy' wiring, then (with the harness disconnected from the AHU) you should see CAN voltage at the AHU connectors - that will prove, in the absence of 'scoping the signal, that the module is powered up and capable of communicating as well as good pingrip on the power & CAN lines.
|  8th Mar 2023 9:21pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Here’s the ECU.
|  8th Mar 2023 10:19pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Bit more testing today.
|  9th Mar 2023 11:13am |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I’ve taped the loom back up with fabric tape and refitted it to the car this afternoon.
|  9th Mar 2023 4:50pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Have also just done the following:
|  9th Mar 2023 5:24pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | Got to admire your persistence David   | ||
|  9th Mar 2023 5:48pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | The CAN to the AHU essentially comes from the instrument pack, which is a bridge to the PATS module (most likely source of door open/closed data) and also a gateway between the MS-CAN & HS-CAN.
|  9th Mar 2023 6:49pm |
| Posting Rules
 Somewhat ironic if it ends up being the £11 switch but here’s hoping
