![]() | Home > Maintenance & Mods (L322) > service components |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
Easy DIY jobs …
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Who did the last service? Clearly not reset the service interval by sound of it |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
If you have owned it for a year? Could this be the service counter simply clicking over 365 days since it was last reset? By the last service technician? I'm assuming you didn't reset the counter when the engine service was carried out? |
A brake fluid flush due to the age of the car would be a good idea but it's not a straightforward DIY job ( do a search on the forum) especially if the front bleed screws are seized in the callipers through galvanic corrosion. Any preventative rust protection is worthwhile if you are keeping the car but probably best done in the warmer months. 2012 TDV8 Vogue (L322) |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 151 ![]() ![]() ![]() |
Thanks everyone, all useful comments.
MAPT is Manifold absolute pressure and temperature sensor.
AFAIK It’s just pressure ‘MAP’ - the IAT ( intake air temperature) is a separate sensor infront of the throttle plate and egr inlet which stays clean 2012 TDV8 Vogue (L322) |
Extract from Workshop Manual.
Logically temp data is needed in the plenum as EGR gasses are being added. 2012 TDV8 Vogue (L322) |
