![]() | Home > Maintenance & Mods (L405) > Start stop button |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
When you press the button in the lower centre consol ot lights up white. The light on the right side of the speedo also goes white. That's a change from green. 2017 5.0 Autobiography Supercharged
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 77 ![]() ![]() ![]() |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
will check. overfinch modified |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
My start stop engine button, glovebox buttons and vent adjusters do not light up. (2016MY Autobiography, all these parts are the same as your 2017)
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 235 ![]() ![]() |
Start/Stop button should illuminate, feed is blue/white wire to switch. |
The engine stop-start button lights up when the lights are on. Vent winders are not lit. overfinch modified |
I've told a lie..m CaymanBlack is correct the start stop button does light up. (2016MY)
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 153 ![]() ![]() ![]() |
Quite possibly unrelated but my car, when I first acquired the car, was a very dull place inside. The main battery was on its last legs with a low voltage and the stop/start feature would only very occasionally operate. Once a new battery was installed the stop/start works a lot and the cabin has lots of mood and door lighting that it didn't have on the old battery. My stop/start button that was a fumble around the dash when you entered the car in the dark but now with the new battery its a bright beacon on the facia. |
