Home > Maintenance & Mods (L405) > Start stop button
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
Start stop button
Can someone tell me if the start stop button on a 2017 ab should illuminate?
I am used to Audi's where the start stop and the blower vent indicators light up but nothing on mine does. Is this normal?
Post #659066 10th Mar 2023 8:36pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
When you press the button in the lower centre consol ot lights up white. The light on the right side of the speedo also goes white. That's a change from green. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #659069 10th Mar 2023 8:45pm
Ryanmt
This is how mine looks. The centre console is all lit up normally. It's the vents, start stop and glovebox buttons that are dark
Post #659073 10th Mar 2023 9:04pm
caymanblack
will check. overfinch modified
Post #659105 11th Mar 2023 11:59am
MarianaWestminster
My start stop engine button, glovebox buttons and vent adjusters do not light up. (2016MY Autobiography, all these parts are the same as your 2017)
I think that's just how it is on these.
Post #659120 11th Mar 2023 4:36pm
Fifth Horseman
Start/Stop button should illuminate, feed is blue/white wire to switch.
Post #659175 12th Mar 2023 9:53am
caymanblack
The engine stop-start button lights up when the lights are on. Vent winders are not lit. overfinch modified
Post #659224 12th Mar 2023 7:53pm
MarianaWestminster
I've told a lie..m CaymanBlack is correct the start stop button does light up. (2016MY)
Post #659278 13th Mar 2023 9:46pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
Quite possibly unrelated but my car, when I first acquired the car, was a very dull place inside. The main battery was on its last legs with a low voltage and the stop/start feature would only very occasionally operate. Once a new battery was installed the stop/start works a lot and the cabin has lots of mood and door lighting that it didn't have on the old battery.
My stop/start button that was a fumble around the dash when you entered the car in the dark but now with the new battery its a bright beacon on the facia.
Post #659500 15th Mar 2023 8:25pm
