![]() | Home > Maintenance & Mods (L322) > Surround Camera Retrofit on a 2011 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8762 ![]() ![]() ![]() |
IIHO they are a gimmick and a bit of a waste of time, the angle puts a car in view a split second longer, not enough to aid you pulling out as you have both ways AND the camera to check before pulling out...
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
Interesting point Pete. Tom
See if someone close to you can let you have a go with theirs... the only way to tell is to try it... you are welcome to look at mine but it's a bit of a trip...!! Pete
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Pretty old tech now. I wouldn't bother to be honest.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
I don't ever use mine! Bit of a gimmick... |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Like Craig said, same here plus have you seen the cost of the cameras? L322 TDV8 2011 Autobiography
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
I do use mine.
chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 46 ![]() ![]() |
The only thing useful is the Kerb View 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 199 ![]() ![]() ![]() |
buy chinese 360 bird view set. |
georgekale Member Since: 16 Jul 2015 Location: IL Posts: 22 ![]() ![]() ![]() |
You're right! I'm doing the conversion now. I have all the parts. just trying to figure rear camera harness for the camera. I'll keep you posted. |
5c0tty Member Since: 07 Sep 2015 Location: Long Buckby Posts: 25 ![]() ![]() ![]() |
Hi there did you manage to retrofit the cameras?
How did the Chinese 360 kit workout? |
