Home > Maintenance & Mods (L322) > Replacement FBH remote?
SvenGB
Hi folks, had a couple of Discos previously and I’m now the new owner of a MY12 L322 Westie.
I looked up the VIN and seems it has “Park Heating with Remote Control [043AV]”, can I assume that’s Remote FBH?
If so, I don’t have the remote - could someone kindly point me towards where I’d find a replacement?
Post #660095 23rd Mar 2023 9:52am
DrRob
Yes it will have it fitted. All tdv8 have them. You can programme it on the centre screen for specific times. Or you on demand via a small remote blipper. Or fit an Altox and control it via an app and SIM card in the Altox. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660097 23rd Mar 2023 10:27am
DrRob
There is a specific type of remote blipper for your model year. I have a 2011 and the blipper does not have the little protruding aerial. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660098 23rd Mar 2023 10:29am
SvenGB
Thanks DrRob! The Altox sounds great, I had similar in my Transporter previously. Any recommendations for where to get one?
Post #660101 23rd Mar 2023 10:56am
DrRob
Ian Bodsworth fitted mine at the same time he Megaflushed my gearbox recently.
He’s on Facebook: “Updates by Bodsy” Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660104 23rd Mar 2023 11:12am
DrRob
This is the one I have
https://www.ebay.co.uk/itm/Webasto-Telesta...635-2958-0
Check the receiver module in the rear boot side bin and see if it says T91R on it. Should do for your model year. The blipper in the link is T91R. There is a syncing procedure. Will be on here somewhere Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660120 23rd Mar 2023 1:48pm
darrenm
That’s a t91 remote not a t91r
Post #660138 23rd Mar 2023 5:07pm
garyRR
Be aware there's different remotes based on chassis number for the 2011 model year.
There was a topic on this recently:
https://www.fullfatrr.com/forum/post644977.html#644977
You need to get the exact remote according to your chassis (of which there are 3 versions), otherwise it won't work. Ordering from main dealer with your VIN will probably be less hassle for not much more money (I think they're just over £100).
An alternative solution is to hook up a GSM gate opener to a timer switch, this will enable you to use your phone to activate the Webasto, but does involve some technical knowledge and a little bit of wiring.
If the remote is missing, there's a good chance the FBH might not have been run in some time. The fuel pumps are known to corrode and cause problems. Try firing it up from the infotainment system (ambient temperature will need to be below 16 degrees, so test late in the evening). If it doesn't work, you may also need a new fuel pump for it (not the end of the world and readily available on ebay).
Can be swapped over in 10 minutes with no more than a socket and extension:
https://www.fullfatrr.com/forum/topic64152.html 2015 Range Rover Autobiography 4.4 SDV8
Post #660155 23rd Mar 2023 7:17pm
DrRob
Oops. Thanks for clarifying my mistaken eBay link.
Bloody minefield these remotes 😂
I’ve ditched mine for an Altox. Much better to be app driven plus acts as a tracker as well 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660170 23rd Mar 2023 9:28pm
