![]() | Home > Technical (L322) > Juddering on hills |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Hello all
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
Put the gearbox in sports mode - if it is the torque converter it should not judder |
It judders in sport mode as well.
bogdan xtr Member Since: 06 Nov 2020 Location: bucharest Posts: 8 ![]() ![]() ![]() |
Oil change. |
It had a flush a couple of years ago. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
My 08MY ended up getting a gearbox flush every time it began juddering. Started doing it at about 80k miles and did a flush each 25k miles thereafter. The older I get, the more I realise that people confuse wrinkles for wisdom |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
I’d definitely go for the oil change and Dr tranny as a first stop, it wont fix a worn torque converter but will help it along the way and probably extend its life if no damage has occurred. I had this issue with my 09 and adding Dr tranny with annual oil changes bought me an extra 3 years before it came back permanently! |
If it only happens on hills it could be something related to the front suspension - the weight of the car moves to the back going uphill reducing the load on the front and giving worn parts more room to bounce around. I would get the car in the air and start checking everything you can for play. |
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 ![]() ![]() ![]() |
I had the same problem recently, juddering / cattle gridding for a few seconds whilst pulling away up from say a roundabout a slow speed. I spoke to various experts who were mainly of the opinion of the cause, it was likely to be the torque converter. I eventually opted to go to Mackie's in Glasgow ZF gearbox specialists and manufactures with a very good reputation. I explained I wanted a transmission service and mega flush.
WDRR - so was this the valve body where the bushes had failed? |
They didn't say they had actually failed but that they were worn as were the seals causing a loss of pressure. Sorry I didn't get any more detail apart from being inform it was a common problem on that Transmission / RR. Apparently they ordered a replacement Kit of some sort that replaced them all. They did not however touch the electronic unit inside the gearbox. Willie
Sonnax zip kit perhaps? I'm just leaving this hear for a future searcher - always good to have the solution to a problem at the end of a thread! |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
The worn bush issue relates particularly to the rear stator bush, which also acts as a seal for the E-clutch hydraulic circuit. Ultimately this can result in the loss of 4th, 5th & 6th gears.
I’ve put two bottles of Dr Tranny in today and the judder has gone. Drives lovely again. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
