|  | Home > Technical (L322) > Juddering on hills |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      |
 Hello all
|  25th Dec 2022 6:21pm |
| lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 63      |
 Put the gearbox in sports mode - if it is the torque converter it should not judder | ||
|  26th Dec 2022 1:13pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | It judders in sport mode as well.
|  30th Mar 2023 1:29pm |
| bogdan xtr Member Since: 06 Nov 2020 Location: bucharest Posts: 8      | Oil change. | ||
|  30th Mar 2023 3:09pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | It had a flush a couple of years ago. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  30th Mar 2023 4:33pm |
| JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 811      | My 08MY ended up getting a gearbox flush every time it began juddering.  Started doing it at about 80k miles and did a flush each 25k miles thereafter. The older I get, the more I realise that people confuse wrinkles for wisdom  | ||
|  30th Mar 2023 6:44pm |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491      | I’d definitely go for the oil change and Dr tranny as a first stop, it wont fix a worn torque converter but will help it along the way and probably extend its life if no damage has occurred. I had this issue with my 09 and adding Dr tranny with annual oil changes bought me an extra 3 years before it came back permanently! | ||
|  30th Mar 2023 8:55pm |
| lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 63      | If it only happens on hills it could be something related to the front suspension - the weight of the car moves to the back going uphill reducing the load on the front and giving worn parts more room to bounce around. I would get the car in the air and start checking everything you can for play. | ||
|  5th Apr 2023 12:58pm |
| WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27      | I had the same problem recently, juddering / cattle gridding for a few seconds whilst pulling away up from say a roundabout a slow speed. I spoke to various experts who were mainly of the opinion of the cause, it was likely to be the torque converter.  I eventually opted to go to Mackie's in Glasgow ZF gearbox specialists and manufactures with a very good reputation. I explained I wanted a transmission service and mega flush.
|  10th Apr 2023 4:58pm |
| lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 63      | WDRR - so was this the valve body where the bushes had failed? | ||
|  11th Apr 2023 10:20am |
| WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27      | They didn't say they had actually failed but that they were worn as were the seals causing a loss of pressure. Sorry I didn't get any more detail apart from being inform it was a common problem on that Transmission / RR. Apparently they ordered a replacement Kit of some sort that replaced them all. They did not however touch the electronic unit inside the gearbox. Willie
|  11th Apr 2023 12:45pm |
| lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 63      | Sonnax zip kit perhaps? I'm just leaving this hear for a future searcher - always good to have the solution to a problem at the end of a thread! | ||
|  11th Apr 2023 12:52pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | The worn bush issue relates particularly to the rear stator bush, which also acts as a seal for the E-clutch hydraulic circuit. Ultimately this can result in the loss of 4th, 5th & 6th gears.
|  11th Apr 2023 2:49pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | I’ve put two bottles of Dr Tranny in today and the judder has gone. Drives lovely again. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  13th Apr 2023 5:31pm |
| Posting Rules
