Home > Technical (L322) > Dealer ruined my MOST system by updating software
begg
Australia 2007 Range Rover Vogue SE TDV8 Santorini Black
Put my 2009 L322 in for the airbag recall. This was 3 years ago.
Came back with no MOST system and a bright white screen!!!
After months no resolution. So stuck with it as it is.
Just put up with using phone with bluetooth speaker.
This is my car I only use for towing and off road work.
As you can see the dealer tried a lot but not enough to fix the problem.
The water issue previously only affected the nav module which was replaced.
Any suggestions?
Post #660948 3rd Apr 2023 12:07am
GraemeS
Australia
Was the globebox removed again trying to solve the issue? If not then worth a try to see what you can find that look's out of place, including incorrectly fitted connectors.
Post #660950 3rd Apr 2023 3:38am
begg
Thanks Graeme,
To me it is almost sabotage what the dealer did.
Given up on dealers and some mechanics where I live. Bathurst. Plenty of bad stories of incompetence.
I will start with glovebox removal and start with the IHU and work around the chain.
Land Rover Australia supplied a new Audio amplifier.
Not worried at all about CD, DVD, tv, telephone and navigation.
All available on my phone.
Just be nice to play music on the stereo and have the information screen.
Problem I see, is if i need to replace the IHU or any item it must be recoded. Is this an issue or is there a way around this.
Cheers
Michael
Post #660951 3rd Apr 2023 3:56am
begg
I hope it is an easy fix like that.
I'll keep you posted.
Post #660952 3rd Apr 2023 4:01am
begg
So after a few hours I have a steady orange light on the power button. No flashing orange.
I have linked in sequence
IHU
CD
TSD touch screen display
Digital Radio
Brand new amplifier
I could find no Portable Audio module under the front seats. Bypassed all the redundant modules like phone, TV, nav, DVD
So I still have a message on a white screen saying
In theory I should be able to download the soft ware update now.
Any suggestions?
Thanks
Michael
Post #661007 4th Apr 2023 9:05am
begg
BTW this all is the result of car in for airbag replacement under warranty.
Car was butchered. Broken plastic tabs, bent metal brackets, CD changer electric switch not attached, etc
Post #661008 4th Apr 2023 9:08am
Mikey
Dealt with this on D3, presumably its the same for L322
Needs a special boot disc into the Nav drive, to upload firmware
Post #661024 4th Apr 2023 12:36pm
Mikey
https://www.ebay.co.uk/itm/234402096757
Post #661025 4th Apr 2023 12:36pm
dont pay for it, download it from here,
http://www.disco3.co.uk/wiki/HLDF_CAN_Bootloader_Error ... - .- -.
Post #661026 4th Apr 2023 12:58pm
begg
Thanks Stan and others for your replies.
So it sounds like the software is loaded via the Nav drive which I have removed?
I'll re-install and hope it is not faulty.
I'm after simple. I always use Wayz for navigation now.
What is this I found amongst the wiring?
(I did have a the heated windscreen replaced some time ago. I hope they didn't misbehave besides it being installed pre-cracked!)
Post #661086 4th Apr 2023 9:44pm
begg
Just read the details on the repair disc supplied.
Great news I don't have to go back to a dealer.
I see a potential problem in that I have installed a brand new amplifier unit.
It may need to have it's code put in?
Thanks again.
Updates to follow.
Post #661088 4th Apr 2023 9:51pm
begg
I note the file is for CAN repair. Will it fix my MOST error?
Post #661712 13th Apr 2023 6:29am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i thought MOST finished about 2006 RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #661757 13th Apr 2023 2:09pm
knares
ok, so when did host finish, or is it still on the go RR 2005 4.4 petrol
Post #662024 16th Apr 2023 2:34pm
begg
I just did a WIKIPEDIA search on MOST but the dates were 2007-2011.
I certainly have it on my 2007 Vougue.
I have been told the disc works to reboot both the CAN fault and MOST fault.
I have had no luck.
Considering just getting a new modern stereo system and hopefully plug into the double din connection.
I don't even get the progress bar when I insert the repair disk and left for an hour.
Post #662069 17th Apr 2023 12:24am
