![]() | Home > Maintenance & Mods (L405) > Deployable steps |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
The steps must be stowed to jack the car up sir... Never jack the car up on a deployed step! The brackets are made of cast aluminium and are made to brake in an impact situation so as to not damage the cars structure... |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 111 ![]() ![]() ![]() |
I was following the instructions in the handbook! It was the notes
Well that's as clear as mud now isn't it... |
For anyone reading this in the future... Look underneath your step and there is a recess for the jack. BUT... Only jack the car up with the steps stowed in the closed position... |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 205 ![]() ![]() ![]() |
Ever so slightly contradictory. As a newbie owner I’m glad I saw this post before attempting to raise my car.
I’ve sourced one in eBay, I hope it fits 2017 (67) Vogue SE Corinthian Grey |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8085 ![]() ![]() ![]() |
I guess it's technically correct - the steps need to be deployed to access the jacking points - although why you'd need to access the jacking points other than to jack up the car isn't clear....
Do the steps just unbolt from the brackets? Or is there a trick to getting them off?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
mine are 10mm step to bracket and 13mm bracket to underside of FF.. ... - .- -.
