![]() | Home > Maintenance & Mods (L405) > Split/Cracked lower tailgate... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
Just went outside to have a look at possible rust following Gremlin500's post
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1804 ![]() ![]() ![]() |
That little rose-joint needs sorting too, those have zero protection and rust horribly. V6 Vogue - “Less is More” - less to go wrong! |
The split is not due to someone overtightening it, it flexis every time it's used and mine has split the alloy...
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Mine’s looking ok, but I’m wondering if it’s worth a large washer to help spread the load?
Doesn't look like there is any plate behind it, lean in and press the close button and see how much it flexes...
Yup, just had a play in the slinging rain at the end of a dog walk and I think I can see a little bit of a flex couldn’t make my mind up if it was flexing or I was thinking about it that much I’m seeing things!
I've done this as a temp repair, stainless washers and a replacement stainless flange head bolt... When it gets warmer I'll play some more...!!
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 39 ![]() ![]() ![]() |
Just fixed mine this weekend.
