Home > Maintenance & Mods (L405) > Split/Cracked lower tailgate...
Just went outside to have a look at possible rust following Gremlin500's post
https://www.fullfatrr.com/forum/topic66565.html
Mine doesn't have anything rusty but I did notice this....
A large split where the lower tailgate actuator bolts to the tailgate, when you hit the close button this split opens another 10-15mm at least... Another "not fit for purpose" issue.
I had a look on eBay and there is a split one on there as well so this is obviously a common occurrence...
https://www.ebay.co.uk/itm/115745228206?ha...R97pgbDtYQ
I'll fix this myself, looks like it needs a large thick spreader plate fixing over it, I think some body glue and rivets will strengthen it enough to manage without welding as the alloy here is now workhardened and I think will fracture if welded....
So open the lower tailgate and check for rust, AND splits....
And, yes, I know it needs cleaning, it's been too cold to do a proper detailing since I bought it...!!! Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #661487 10th Apr 2023 1:05pm
Gremlin500
Yes, thats one of the two I replaced with painted ones, got genuine LR galvanised bolts and an expensive can of Corris Grey, 3 light coats. Looks like somebody was totally heavy-handed there! V6 Vogue - “Less is More” - less to go wrong!
Post #661491 10th Apr 2023 1:16pm
Gremlin500
That little rose-joint needs sorting too, those have zero protection and rust horribly. V6 Vogue - “Less is More” - less to go wrong!
Post #661492 10th Apr 2023 1:18pm
The split is not due to someone overtightening it, it flexis every time it's used and mine has split the alloy...
I'll sort the bolts and other rust when I do it... Thumbs Up Pete
Post #661497 10th Apr 2023 1:46pm
TJH1985
Mine’s looking ok, but I’m wondering if it’s worth a large washer to help spread the load?
I’d be interested in seeing some pictures when you dissemble it, I presume the back of its quite a large plate.
Edit: Found it as LR034445 Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #661524 10th Apr 2023 6:18pm
Doesn't look like there is any plate behind it, lean in and press the close button and see how much it flexes...
I would say a large square stainless repair washer would help... Thumbs Up Pete
Post #661533 10th Apr 2023 7:28pm
TJH1985
Yup, just had a play in the slinging rain at the end of a dog walk and I think I can see a little bit of a flex couldn’t make my mind up if it was flexing or I was thinking about it that much I’m seeing things!
Either way I think I’ll have that bolt out and fit a larger washer to spread the load. The bolts look like the could be long enough to accommodate one behind the standard washer.
Good spot sir Thumbs Up thanks! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #661536 10th Apr 2023 7:53pm
I've done this as a temp repair, stainless washers and a replacement stainless flange head bolt... When it gets warmer I'll play some more...!!
The lower tailgate didn't always open properly, maybe 80% of the time, now it works just as it should all the time.
It had a new lower tailgate mechanism a short while ago under JLR warranty, I guess the fitter didn't notice a 2" split in the bodywork, or couldn't be bothered... Rolling Eyes
Working well now though.... Thumbs Up
 Pete
Post #661584 11th Apr 2023 11:48am
sass
Finland 2016 Range Rover Vogue TDV6 Kaikoura Stone
Just fixed mine this weekend.
There was an emerging crack on both sides of the washer which could be clearly felt by running a finger over it. You can also see a fine line at 10 o'clock if you look close enough on the other image.
Post #704227 11th Nov 2024 12:35pm
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Keen to do this on mine. Would I be right to assume that the nuts are captive, so I can fully remove the bolt without the nut dropping into the unknown....?
Post #723072 19th Aug 2025 8:41am
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
From the picture above of the internal bracket placed on its side (copied below), it looks like both nuts are captive and firmly fixed.
https://www.fullfatrr.com/gallery/albums/u...acket.jpeg
I foresee a weekend job for me coming on! Very Happy
now... where did I put those penny washers? 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #723077 19th Aug 2025 10:54am
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
From my recent experience the problem is caused by the ball and socket coupling between the hinge fixed to the vehicle body and the actuator fixed into the tailgate (as per the photo).
What you can’t see is how the coupling rusts internally and seizes in quick time, thereby jamming the actuator and causing the metal of the tailgate to fracture.
That coupling is one to clean out and grease frequently because it is exposed from beneath.
I wasn’t aware until the tailgate wouldn’t close, then saw the ball and socket had popped due to rust.
Cost me a new hinge and actuator to sort.
Post #723107 19th Aug 2025 8:20pm
