Home > Maintenance & Mods (L405) > 4.4 V8 Diesel Suspension type / issue
evotime
Done loads of reading so apologise if the info is already on here.
I have an annoying, what only can be described as a shoogle, like a rear shock is knackered and not damping properly when going over an undulations on the road. If only 2 wheels hitting the undulation moving the car left and right it shoogles like its under damped. (difficult to describe)
The more I read the more pops up with all manner of possible issues including the ARC/ACE system
Looking for a replacement shock I see they come described as with CVD and without CVD. What is CVD? I am guessing its the ARC/ACE system equipped car?
Car seems a wee bit tail happy going round left hand bends so guessing (not had it on my ramp yet) that the right rear shock is the culprit. X5 40d
Post #661685 12th Apr 2023 6:42pm
knwatkins
CVD is constant variable dampers. It means the dampers are controlled by a controller that signals to the dampers to adjust their damping behaviour depending on the terrain/road conditions/driving style.
Have a look at the top of your strut assemblies under the bonnet. If you have an electrical connector, you have CVD.
As you have an SDV8 with ACE(old term)/Dynamic Response you will most likely have CVD. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #661686 12th Apr 2023 6:49pm
evotime
Thanks for that. Most informative X5 40d
Post #661688 12th Apr 2023 7:03pm
GraemeS
Australia
Rear CVDs have an extra oil chamber attached to the lower part of the shock, facing inwards. Check that both are still attached as they can get knocked off if they've hit something. If one is missing then that shock won't have any oil left so will be totally useless.
Post #661701 12th Apr 2023 11:47pm
evotime
Thanks for that. Should be an easy enough check. X5 40d
Post #661713 13th Apr 2023 6:54am
evotime
knwatkins, you were correct Thumbs Up X5 40d
Post #661753 13th Apr 2023 1:41pm
Believe it or not, the oil reservoir canister is actually glued to the shock not welded, go over a bad pot hole and the sudden increase in pressure can just pop the reservoir off...!!! Pete
Post #661813 13th Apr 2023 11:34pm
I note you're from Scotland and thus more rust! Ive changed quite a lot of rear dampers with rot holes in the shocker reservoir... Quite normal... Thumbs Up
Post #661817 13th Apr 2023 11:45pm
evotime
Thanks lads, seems a very poor design.
What's the score if aftermarket shocks, anyone used them?
Aerosus is one company that keeps popping up. 2 for £450 with 2 year warranty. There are cheaper at around £350 for rears X5 40d
Post #661824 14th Apr 2023 7:03am
