Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 9 of 35 <123 ... 8910 ... 333435>
MarianaWestminster
Fisha,
Great to hear of the improvement in going to a 60 profile on 20 inch.
I wish I hadn't just bought 2 new tyres and I could find a set of 20s I liked on the 405 as I would consider it.
For me personally they just don't look right on any less than a 21 inch but that's just me.
Laughing
As for steering, I'm back at factory pressures for 16MY which is 34 front and 37 rear.
My steering and Haylands steering is similar but not as light as what I see in this video below, perhaps there are different steering tunes for different markets?
I'm between a rock and a hard place now as this 405 and my last 2 322s have failed to recapture the adoration I had for my 2009 Westminster.
If I try to live with it I know I'll spend the whole time looking for and spending money on problems that may not actually exist but if I sold it I don't know what I would replace it with as I can only see my self driving British.
Post #662745 24th Apr 2023 9:38pm
fisha
I understand the look comments … still adjusting to the look of mine I think.
found this :
https://static.nhtsa.gov/odi/tsbs/2016/SB-10106315-9340.pdf
Worth a look perhaps … some of the suggested codes are close to what you showed. V8 or else ...
Post #662752 24th Apr 2023 10:07pm
MarianaWestminster
Thanks for the service bulletin, I've seen that one before and cleaned up the grounds mentioned (they weren't bad to be honest) as well as replace both batteries to ensure good power.
Replacing the batteries did get my start stop working again but not much else Laughing
Post #662762 25th Apr 2023 7:32am
I'm really not a fan of black wheels, comes from being old enough to remember when everyone had black steel wheels with a nice silver full wheel trim, lose the trim and you just had black wheels, which everyone seems to be wanting today....
Anyway, I digress, put 20's on but make them black and it won't show what size they are.... Thumbs Up
These could be 20's or 22's...!!
 Pete
-Click here for Thread-
Post #662763 25th Apr 2023 8:28am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
MarinaWestminster, are you in a position to be able to temporarily swap your wheels for 20’s? Just to see what difference it makes?
You can then decide if the change to the look vs ride improvement is worth it…
The bigger side walls always make a difference, and thats why i went for 285/45/R22 on mine. Effectively it added an extra inch to my tyre wall.
I had to adjust my speedo, and in extremes it has rubbed, however I am happy with that change. My next change is to loose my cheapo tyres and put on some decent rubber.
This may (or may not) also help with my issue. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #662765 25th Apr 2023 8:49am
Ffrr-lover
You also mentioned fairly early on about a Vehicle Reset.
I was sat in the car waiting for the other half the other day, and popped in the IIDTool to look at any error codes of interest (there were none), but also looked through the different options available (i was getting very bored waiting) and stumbled upon the Vehicle Reset option so thought “why not!”
Caveat! The issues we are seeing seem to come and go, and we have no idea what the cause is. There is also a large amount of “in my head” going on too i am sure… so what I state below may have NOTHING to do with the vehicle reset!
After the reset, and the loud FM static from the radio afterwards, we went on our journey. I immediately noticed how harsh the ride was within the first 100 meters. However after a short time into the journey i then noticed that the car seemed to be better than usual. We did an hours journey over a mixture of road surfaces and I was happy. The same on the return journey (after a 3 hour stop).
The article posted by Fisha intrigues me as it shows that something voltage related can affect your steering… can the same be happening to the CVD system? Or something that has an effect on it?
Is cranking a cold car in the morning just enough to sometimes cause a problem?
I’ll certainly be cleaning up my terminals, and charging the battery as a “why not” step.
Still, good luck with everything! Hopefully you are getting nearer to being happy with your car. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #662766 25th Apr 2023 8:57am
Ffrr-lover
Just to be clear, I dont think the reset has fixed my issue as subsequent journeys seems to be a mixed bag again… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #662767 25th Apr 2023 8:59am
MarianaWestminster
Sadly Haylands I also couldn't fit Black wheels as I really, really don't like them unless its on an all Black car. But I get the point you are making...
FFRR
I'd have to buy a set of 20s to be able to test them but having just spent £460 odd on 2 new front Verdes it'd have to be a big improve to help me swallow that cost.
I've used that vehicle reset option via IID on my last 2 x 322s and via SDD on this L405 and I find the same as you, it helps a bit then the car goes back to how it was.
I now know what normal is for a 405 thanks to Haylands and I can now tell when my car is and isn't at normal. (Driving home on Sunday was 'normal' driving to work this morning was not)
Yep voltage can definitely effect the electric power steering on a 405, its even mentioned in the WSM but I don't think this is my issue.
I am trying to convince myself its me being hyper sensitive but when I see videos like the one I linked with light, smooth steering and articles describing the L405 as 'the off road S class' I do wonder.
I think i'm going to have to stick with it for a bit but its likely it will move on especially with my autotrader search currently being set on facelift Bentley Arnages.
Post #662768 25th Apr 2023 9:09am
Good morning all. Replaced my rear shock absorbers over the weekend and she's back to her best.
My 2peneth worth... My wife's 405 is a 13my with 21" wheels and standard height setup albeit running 15mm spacers as the standard wheel to wheel arch ratio to my eye looks a bit pinched.
My car is a 15my LWB Its lowered and is running 23" wheels with 285/40 Pirelli silents and I MUCH prefer the ride quality of my car than my wife's... My steering is direct, sits on roads/motorways in a straight line tracking true. Wifeys tram lines everywhere! Self steers on cambers and is quite the opposite to others opinions on here...
all the above is obviously just my unscientific opinion. BUT, I am certain the LWB helps with forward backwards bucking (like a defender 90 compared with a 110)
Maybe go try a LWB Mariana? Thumbs Up
Post #662776 25th Apr 2023 10:18am
caymanblack
Mines also on 23" rims and drives as Craig does, no complaints about the quality at all.
Mariana that car in your video even has snow tryes! overfinch modified
Post #662791 25th Apr 2023 1:06pm
MarianaWestminster
Good to hear you've sorted yours out Craig.
I'm sure the extra length in the wheelbase of an LWB model probably helps but unfortunately it wouldn't help me with mine Laughing
Cayman, does the fact it has snow tyres mean the steering would be lighter or would one expect it to be heavier with snow tyres?
Do either yours or Craigs cars steer as effortlessly as the one in that video?
It's all down to individual perception though, you both feel your cars are fine on 23s whereas I might not.. but the key thing is you are both happy and that I wouldn't knock Thumbs Up
All I want in my every day car is supple, comfortable suspension and fingertip light steering.
If the L405 cannot be modified to give me that then I wonder which car would?
Post #662793 25th Apr 2023 1:27pm
Out of interest and going slightly off piste! What tyre size are you running on your 23’s
I’m running L460 factory 23” tyres so 285/40/23 Pirelli silent summers and 275/40/23 Pirelli silent all season winter tyres. Both give massive rim protection over and above the aftermarket 23” tyres which were 285/35/23 from memory? And are much more like rubber bands imho of course…
Post #662796 25th Apr 2023 2:49pm
caymanblack
Hi Craig, Mine are Toyo Proxes Sport SUV 285/35 ZR23 107Y.
Mariana I would have thought the tyres on that video car would make everything worse.
Snow tyres with the studs.
Steering on mine feels effortless . overfinch modified
Post #662798 25th Apr 2023 4:44pm
MarianaWestminster
Okay that makes sense Cayman as I would think the same.
So you've got larger wheels with wider tyres than standard (285s vs 275s on factory 22 and 21 inch wheels) and its effortless which is how I would have described my old Westminster. (It was like the video above)
Wish I could find it as I would buy it back!! (KV59 ZVS)
Post #662799 25th Apr 2023 5:10pm
MarianaWestminster
Well my 405 was in a good mood tonight.
Pulled away from work and we had...
Supple suspension with damping
Palmable steering
Responsive SDV8 engine
I was enjoying the drive home so much I went the long way (an extra 10 miles!) Even went over some pretty crap roads and it handled them so much better than it usually would.
If you'd have blind folded me and put me in the car I would have said I was in a completely different car.
Why can't it be like this every drive, every day?
Post #662818 25th Apr 2023 9:05pm
