![]() | Home > Technical (L405) > Suspension Groaning when going down to access mode |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 460 ![]() ![]() ![]() |
Any knocking from the suspension on uneven road surfaces?
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
As above anti roll bar bushes and drop links ball joints are possible causees, also on a 322 you can get a tiny bit of groaning when all is well if you drop to access height when the steering is turned over to full lock. Would imagine a 405 can do the same. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Try it without the park brake on and no foot brake. Also do it on the level and in neutral. Does it do it then? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Jay Porsche Member Since: 22 Jan 2023 Location: Solihull Posts: 60 ![]() ![]() ![]() |
No knocking at all its perfect whilst driving.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
I expect that is the pads getting pulled down the disc as the car lowers, as it lowers the wheels need to move a fraction in relation to each other, in park the brakes aren't on...
