Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 12 of 35 <123 ... 111213 ... 333435>
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
Whilst I can’t really add any constructive help I think it is accepted that the best ride is with 20” wheels as a thicker tyre wall obviously helps smooth high frequency shakes. If steering sharpness is required then obviously 21” or 22” will be more to your taste.
The 20” wheels are also narrower so less prone to tram lining. These smaller wheels can be picked up pretty cheaply so maybe more suitable for you.
I used to have a BMW 760i and that was definitely more “wafty” than my Range Rovers, seemed to just glide around in its own bubble of comfort. Whilst my Range rovers have never matched this I still find them smooth, comfy and refined but it’s all a spectrum I guess and partly subjective too. My current FFRR is on 20” wheels and am I happy with the ride and although aesthetically maybe the bigger wheels look nicer I rank comfort over style so the 20’s are staying. 2013 SDV8 4.4 Vogue SE Aintree
Post #663676 8th May 2023 9:50pm
MarianaWestminster
Your on 23s aren't you CaymanBlack?
I personally definitely wouldn't go to any larger wheel than mentioned could have been an option if there was a style I liked and I hadn't just spent £470 odd on 2 new tyres.
Its all a matter of opinion as I imagine I wouldn't be able to cope with 23s on...
Just struggling to believe that this is suppost to be how an l405 is.. if I'd just bought a brand new one and it was like this it would be going straight back for refund.
Post #663679 8th May 2023 10:23pm
caymanblack
Hi Mariana , yes I,m on 23" but I don't notice any tram lining or other problems perhaps slightly more tyre noise? overfinch modified
Post #663697 9th May 2023 9:40am
MarianaWestminster
Couple of questions for you CaymanBlack out of interest if it's not too much trouble...
Given you have 23 inch wheels I expect if the issues I have are normal to the l405 you might be able to notice them on yours?
1. At 30-35mph and above a constant feeling of the road surface being transmitted through the car. (Body, pedals, seats and steering wheel)
2. Passenger seat visibly shakes/trembles above 40 mph. Especially noticeable at motorway speed 70mph
3. Power steering heavier on the first cold start of the day, better later on in the day but not always guaranteed.
4. No consistency in the drive... can get in and drive for a bit, park up and nip into the shop come back out and now the ride might be harder or the steering heavier it doesn't drive the same every time
Thanks in advance!
Post #663739 10th May 2023 9:29am
caymanblack
That is very easy to answer Mariana as, I have just done a trip from Devon to Essex and back in the car and took note of your issues and the answer to all your questions is NO. overfinch modified
Post #663740 10th May 2023 10:18am
MarianaWestminster
Thanks for the feedback CaymanBlack, much appreciated.
I'm even more confused now as that suggests I have issues but Haylands thought my car drove okay and I thought his was similar.
The frustration continues
Post #663747 10th May 2023 12:43pm
fisha
Not in a harsh way as you describe. But in mine, I would say that I feel the road through the whole car. It feels lighter and tighter to me than the L322 to drive, and as a result I do think I feel the bumps more than before. Even with the big soft tyres I have at the moment.
Defo not.**
Cant say I've noticed the steering feel change from trip to trip. The steering is heavier than a modern saloon car like a focus or pug 308 though.
4. No consistency in the drive... can get in and drive for a bit, park up and nip into the shop come back out and now the ride might be harder or the steering heavier it doesn't drive the same every time.
As per #3. Mine feels consistent.
** This comment though ... tremble at speed like that you feel through the car would have me looking at the wheels. You're describing exactly what I was feeling before I changed my wheels. Admittedly I knew that my tyres were wildly out of balance due to uneven wear, but it manifested in a tremble you could feel at 30mph and higher. Wasn't all out shaking, but would make water in a bottle ripple. I know that you've had them off, balanced etc etc etc. but are they fitting correctly flush?
The mating surface between the wheel and the disc on the hub and centre spigot needs to be very clean and free of any debris at all.
Is it possible that there is something on one of the mating surfaces of the wheel, the disc face, the area around the centre spigot that is preventing a wheel from fitting perfectly flush ?
I've found so far the L405 wheels to be a very tight fit onto the hubs compared to my previous cars, and that there was a lot of white corrosion build up around the centre spigot which I had to scrape away
It might me that although when you put the wheel on it feels like its fully home, but in reality a small something is preventing it from being just perfectly sat on the hub. This would put the wheel out of alignment to the direction of tracel and make it shoogle ... but wouldn't show up on a wheel balance machine. V8 or else ...
Post #663795 10th May 2023 7:59pm
MarianaWestminster
Thank you for the feedback Fisha.
When I had the wheels and tyres road force balanced I watched the 2 technicians do a great job of cleaning up the hub faces and spigots as well as the mating face on the wheel. I was really impressed by the attention to detail, care and pride they took in their work
I've re attached my video of my passenger seat from earlier in this thread for all to see again for feedback.
https://youtube.com/shorts/eqajrVGZqeg?feature=share
Post #663804 10th May 2023 9:24pm
The only thing I can see is camera shake... Pete
Post #663814 10th May 2023 10:11pm
MarianaWestminster
Bloody awful this morning, rock solid ride and heavy steering no feeling of a 'luxury 4x4' at all more like an old tank smashing it's way down the 60mph country road from my house to the main road.
Last edited by MarianaWestminster on 6th Nov 2023 12:09am. Edited 2 times in total
Post #663828 11th May 2023 7:26am
caymanblack
That Granada is just lovely Mariana, as my dad had three I was driving them at 17.
2.8 Ghia. 2.8i Ghia X was my favorite.
Is that Caspian Blue? overfinch modified
Post #663837 11th May 2023 9:35am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I had a thought whilst I was out today.
With the inconsistent ride in mind… This happened after the compressor was replaced.
The compressor should not have any impact in ride quality, however have they knocked something during that work? The L322 has an accelerometer in the spare wheel well which is where the compressor is. If you L405 is no different then defo check that accelerometer is correctly fitted, and there are no signs of knocks or damage to its wiring? If slightly out could it be on the cusp of reading in such a way that the suspension is stiffening? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #663854 11th May 2023 2:16pm
Ffrr-lover
Oh, and love the look of this car! She is a beauty! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #663855 11th May 2023 2:17pm
MarianaWestminster
Thanks Cayman and FFRR. She is lovely, a genuine 1 owner with 66k miles ok the clock.
Post #663874 11th May 2023 5:14pm
MarianaWestminster
Good thought FFRR, the accelerometer isn't mounted in the spare wheel well from what I can see compared to the 322.
Everything looks to be fitted correctly back there and I checked my letter I wrote to the JLR tech when the car went in and I'd noted before hand the ride was firmer than expected...
At the minute it's acting just like my previous 2 L322s. I must be cursing these Range Rovers
Post #663875 11th May 2023 5:16pm
