Home > Technical (L322) > Restricted Performance - Limp Mode
Davidlm
United Kingdom 2012 Range Rover Vogue TDV8 Bonatti Grey
Good afternoon,
I am having problems with my 2012 L322 4.4 tdv8. It brought up the yellow restricted performance light so I put it in the garage. It came up with a fault with the EGR temp sensor, bought a new one from JLR, had it fitted and same fault appeared. Went onto the forums and the suggestion was it would be the exhaust gas temperature sensor down the side of the engine. Bought one from JLR, bought the special tool you need to fit it and low and behold.... Same fault only it now actually goes into limp mode when you accelerate over 2000revs. It has the newer inlet pipes fitted with the white writing on them and they have done a smoke test with no leaks found. The turbo actuator is moving freely, so I and they are running out of ideas??
Suggestions please.
Post #663749 10th May 2023 12:56pm
Dolphinboy
have you had a HIGH pressure smoke test done? My Pax side inlet manifold head a minute crack in it but set off RP when I demanded power to go up a hill.
Post #663750 10th May 2023 1:18pm
Davidlm
Yes, did the high pressure smoke test but nothing showed up.
Post #663753 10th May 2023 1:55pm
andygts
Has the MAP sensor been cleaned? quick and easy to do. I can't remember if mine threw a code up or not for it but a quick spray with some carb cleaner and it's been fine ever since. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #663756 10th May 2023 2:33pm
JayGee
What was the fault code exactly? 2012 TDV8 Vogue (L322)
Post #663757 10th May 2023 2:40pm
DrRob
My suggestion. Take it to either T&S Norman in Shepton Mallet or Craig at Cam-Tech and they'll diagnose it in 10mins Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #663758 10th May 2023 3:07pm
Dolphinboy
what Rob said. Only Steve at Norman's are allowed to touch my RR now. They were the only ones who took time to correctly diagnose what was happening and came up with a correct fix. MD and LR garages all failed to come up with a solution.
Post #663762 10th May 2023 4:04pm
Davidlm
I will keep their address and details in my phone for the next time!!
I think it is fixed as the fault codes are all gone and after a 10min test drive, no warning lights or limp mode. There was a chaffed wire to the rear o/s of the manifold that they repaired and the fault codes went!!
I think it was the exhaust temperature sensor fault to start as it came up with a different fault code relating to the turbo boost after that repair was done.
Thanks for everyone's help. I will let you know once I have driven it for a couple of days. 2012 Range Rover Vogue 4.4 TDV8
Post #663774 10th May 2023 5:49pm
