Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 13 of 35 <123 ... 121314 ... 333435>
MarianaWestminster
I've found an SSM (SSM 74642, not sure how I can attach a pdf here?)
It specifically talks about 18-21MY L405 sensitivity to wheel balance and mentions the following:
'Customers report a vibration felt through the base of the drivers seat and are visually able to see the upper section of the passenger seat shaking'
Interesting.
Post #663876 11th May 2023 5:19pm
MarianaWestminster
Wrong pic doh!
Post #663877 11th May 2023 5:19pm
I can't read that, quality is low... try this...
A good find, looks like you need a special bit of kit...!!! Pete
Post #663886 11th May 2023 6:34pm
MarianaWestminster
Thanks Haylands Thumbs Up
Post #663889 11th May 2023 6:46pm
MarianaWestminster
Picked up a bargain Ctek MXS 5.0 off Facebook marketplace today so I've stuck my new battery/batteries on charge (connected to underbonnet posts so only charging main battery?)
The charger I had was a halfords normal one so picking up a ctek seems like a sensible idea.
Will see what the battery voltage is when fully charged and if it helps with first start of the day steering.
Post #663948 12th May 2023 1:51pm
MarianaWestminster
Complete Apples to Oranges comparison but...
The steering in it is lighter than my 405 and the ride is more 'cushioned and less 'fidgety'
Last edited by MarianaWestminster on 6th Nov 2023 12:10am. Edited 3 times in total
Post #663949 12th May 2023 1:53pm
knwatkins
It definately sounds like something is not right. My L405 is a much more comfortable ride than my old L320. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #663956 12th May 2023 4:10pm
MarianaWestminster
Your on 22s as well aren't you knwatkins?
Post #663961 12th May 2023 5:03pm
caymanblack
I also had a AB sport and the ride was firmer than my car now. overfinch modified
Post #663966 12th May 2023 5:35pm
knwatkins
I certainly am. Yes, I feel potholes and drain covers in the road, but on the motorway and a roads it's a magic carpet ride. Kev
Post #663970 12th May 2023 6:28pm
MarianaWestminster
Okay and were you both on 275 40 20 with your L320s?
So what could be causing mine to be okay once in a Blue moon (like when haylands drove it and that random day I posted about )
Then shocking like it was Thursday?
Post #663977 12th May 2023 8:18pm
knwatkins
Yes, I had 275/40/20 and then had 255/55/20 as I put some L494 wheels on.
If I were you, I'd disconnect the electrical connectors on the top of the struts and take it for a ride. That'll take the CVD out of the question. If that solves it for you, you can then code them out. Kev
Post #663979 12th May 2023 9:13pm
MarianaWestminster
Thanks for confirming.
If I unplug the connectors the shocks won't be energized at all meaning they will be in full hard mode.
I'd have an even harder ride than I have now?
Post #663980 12th May 2023 9:22pm
knwatkins
I'm not sure which way around they work. But if it were me, I'd give it a whirl. Kev
Post #663981 12th May 2023 9:24pm
fisha
I think they default to a soft mode, and it’s energised to stiffen the damping rate. On the Evoque, if the energise value ran between 0 and 1, iiirc the default energise value was about 0.25, and when in dynamic mode it sat at 0.5 .. so by default dynamic had a stiffer damping all the time. V8 or else ...
Post #663984 12th May 2023 10:01pm
