![]() | Home > Technical (L322) > Top Tip on how to easily remove injector 8 from a TDV8 |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Sounds like a good plan |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Like that, much prefer this to taking the injector apart 2009 (2010 MY) 5.0 Supercharged Autobiography
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I will be doing this job soon hence trying to find the easiest way to get no 8 injector out. Am I missing something here, I am reading this as you are lowering the suspension, lifting the car, putting something between the ground and N/S engine mount and lowering the car. How is that any different to just jacking up the engine without unbolting the mount? Any input from those who have done it is greatly appreciated. Anyone actually removed the solenoid, can anything fall out or is everything left secure. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
Sorry for not responding sooner, only just seen this post.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 200 ![]() ![]() ![]() |
Did someone tried this method with TDV8 4.4 engine? |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 208 ![]() ![]() ![]() |
Here's a YouTuber that has managed to remove Injector 8 using the engine jacking method.
official way is to loose mounts and disconnect a/c and cooling lines, then jack a little through oil pan. |
Having just done a left side inlet manifold/rocker cover gasket I can say that getting the last injector out is no big deal if you follow these guidelines. This is the way Time as Usual did it on his you tube video and I followed his advice. takes 5 mins. Remove the start battery surround to give more clearance for the injector.
