Home > Maintenance & Mods (L405) > L405 SD 4.4 Oil Change (2017)
Suki
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
Ok sorry if this has been covered before, but I have a newbie question I'm sure can be answered easily:
The oil level indicator doesn't work (i've tried the cruise control button process) and so I expect the sensor's faulty.
I had the oil changed by a specialist in November when it had a big service, and now I'm ready to do an oil and filter change myself for the first time.
Since the oil capacity is 9.4 litres, is it simply a matter of meausring this out accurately and pouring in that amount?
Post #664059 14th May 2023 8:48am
With oil capacity you have a minimum and maximum the engine will like, the minimum amount it will run on with no bother is less than the lowest level on the "dip stick" be it a real one or electronic level indicator...
However, the maximum amount is very close to the "full" mark...
You have to take this into account and not over fill it... it wants to be somewhere between the min and max....
IIRC it's a good ltr between min and max so don't over fill it...
Don't measure what comes out as the oil may have diesel in it and remember not all the oil comes out on a change...
I'm not going to say how much I think you should put in but you need to bear the above in mind when filling.... Thumbs Up Pete
-Click here for Thread-
Post #664060 14th May 2023 9:25am
Baltic Blue
I can only relate to the 4.4 in the L322, but anything over 8.5 litres of new oil immediately brings up the “overfilled” refer to handbook message.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #664062 14th May 2023 9:49am
knwatkins
I'd recommend getting the level indicator fixed in the first instance. There really is no reason not to do this. Then you know exactly if you have the correct volume in there to start with.
If you simply replace what you take out, you could:
A) be underfilling because your engine may have used oil (starting off with less than the correct volume)
B) be overfilling because your oil may have been diluted with fuel as a result of DPF regens (starting off with more than the correct volume) Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #664063 14th May 2023 9:53am
knwatkins
That's not the case on my L405 SDV8, Mike. I can suck out exactly 9.4 litres and replace it with 9.4 litres fresh and the indicator will show full. Kev
Post #664064 14th May 2023 9:56am
Suki
Thanks for the replies all. It seems it's not so simple after all.
I guess what I'm asking is 'What did the garage do when I had it serviced in November?"
I don't think I want to bother getting the sensor fixed - it seems like a very expensive job. I will be changing every 6 months, and will probably do less that 6k a year.
THere must be an optimal measured amount of oil for refilling, but I'm hearing that there is no consensus.
Of course, it's obvious that I wouldn't put back in what I take out, since this may have diesel in it.
Kev seems to have actual experience of putting in 9.4 litres without issue. Pete seems to have the opinion (if I understand correctly) that 9.4 would be "Max" on a dipstick, and you should put in something between "Min" and "Max". The question would then be "How many litres are "Min"?"
Has anyone else had experience of putting in a measured amount of oil?
Post #664068 14th May 2023 10:30am
caymanblack
Suki have you enquired about getting the sensor repaired? overfinch modified
Post #664069 14th May 2023 10:31am
Suki
I understand it's a big job, since the sump needs a stripdown. I've heard reports of £900 or more.
I'm really looking to find out how much oil goes in the engine at the oil change.
Post #664070 14th May 2023 10:40am
IIRC it's a huge job on the 405 as the sensor is in the sump, on the 322 it's outside the sump...
If it was me I wouldn't put anywhere near 9.4 ltrs, overfilling is bad news, somewhere between min and max is better....
They make the oil level so high so the engine is not starved of oil when the fatty is at 45degrees or something close, in any orientation whilst off road.
It only needs to be on the full mark if you intend to have the fatty at such angles, normal driving and less is better IMHO.... Thumbs Up Pete
Post #664071 14th May 2023 10:46am
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
oil level
I changed my oil 2 weeks ago i know its supposed to be 9.4 litres to change but i dont like to overfill, i put in exactly 9 litres of smith and allan oil and the gauge reads full - oil level ok hope this helps
Post #664072 14th May 2023 10:58am
Suki
Great thank you! I think this is what I'll need to do.
Post #664074 14th May 2023 11:05am
Kot
Do a search there are other reasons why the oil gauge is not working
https://www.fullfatrr.com/forum/topic62224.html 2018 SE SDV8 4.4 Byron Blue
Post #664078 14th May 2023 12:41pm
