Home > Maintenance & Mods (L405) > L405 Oil Filter - 2017 SD 4.4
Suki
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
I need some help here please - this is driving me mad.
I ordered an SD 4.4 L405 oil filter from a reputable aftermarket suppplier who sent me a Mahle LR022896G, whech I found didn't fit. It has a raised lip on both sides whereas my exisiting one is flat.
I later found out that this filter is only for 2012 and 2013 models, and the L322 TD 4.4 models.
So I ordered a Bosch one which was described as being for the 2014 model onwards. It just arrived and is the same shape as the Mahle one. WHen I checked the part number, this affirmed that is is also for the <2014 models.
Every time I try to search for the correct one, I'm directed to the wrong one!
Does anyone know a reputable suppler for aftermakekret filters for my car in the UK? I really don't want to buy a genuine one from LR.
Any help would be appreciated!
Post #664256 16th May 2023 3:29pm
caymanblack
https://www.amazon.co.uk/Knecht-OX-153-7D2-Filter/dp/B0068MWNYK overfinch modified
Post #664259 16th May 2023 3:51pm
Suki
Again this looks like the one I was sent, and has a lip. Am i going mad?
Post #664260 16th May 2023 3:53pm
caymanblack
Have you removed the old filter? they have to clip in aparrantley so this is the correct one .
I,m yet to do mine but someone posted here about the middle coming out and that it did not look right when in fact it was. overfinch modified
Post #664264 16th May 2023 4:11pm
Suki
Yes I removed the old one. Good job I didn't drain the oil first. I found that the one that was sent to me did not clip in, and had a raised lip around the hole and was longer.
Post #664265 16th May 2023 4:13pm
caymanblack
OK so the only way to be sure is to buy a geniune one from Duckworths here and compare or even ask there advice , they are helpfully to us members. overfinch modified
Post #664279 16th May 2023 7:31pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Amazon Mann HU 718/5X is the best filter you can buy for the 4.4 SDV8. It says pack size 2 but you only get 1.
Post #664442 18th May 2023 6:07pm
caymanblack
Reading what Suki said about the oil filter I,m now wondering why the one I posted above did not fit as it's the same part number .
It does look different to the genuine one though, can anyone confirm?
https://www.duckworthparts.co.uk/landrover...lr022896nr
Your one looks the same Jon are they better than Geniune? overfinch modified
Post #664445 18th May 2023 6:33pm
154JON
I would say much stronger than Genuine the cords that go around the filter stop the filter from deforming keeping the oil path fully open.
Post #664446 18th May 2023 7:33pm
Suki
OK all, I have found the answer to my dilemma.
Firstly, even though some suppliers list 2012-2013 and 2014> separately (and even list different products!), they are all essentially the same.
The Mahle and the Bosch ones I bought both fit.
What threw me was that (a) they were a different shape to the original (had a lip at each end), and (b) when I tried to push the Mahl one in, it didn't want to snap in place. The answer was that it needed quite a hard push.
Please see the pic - The Mahle, the Bosch, and the original. They are exactly the same overall hight, but the original does not have a lip.
I can also report that the top of an Evian bottle is an exact fit for the oil filler and makes an excellent funnel.
Post #664604 21st May 2023 12:48pm
Suki
Post #664606 21st May 2023 12:49pm
caymanblack
Thanks Suki I was worried a bit there but glad to see they all fit. overfinch modified
Post #664616 21st May 2023 4:29pm
supershuttle
I know this is an old thread but I just got supplied a OX153 D3 will it do or should I send it back and get a D2 ? Geoff
Post #673209 12th Sep 2023 1:11pm
