Home > Maintenance & Mods (L405) > L405 Oil Filter - 2017 SD 4.4 |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1060 |
https://www.amazon.co.uk/Knecht-OX-153-7D2-Filter/dp/B0068MWNYK overfinch modified |
16th May 2023 3:51pm |
Suki Member Since: 21 Oct 2022 Location: London Posts: 14 |
Again this looks like the one I was sent, and has a lip. Am i going mad? |
16th May 2023 3:53pm |
Have you removed the old filter? they have to clip in aparrantley so this is the correct one .
16th May 2023 4:11pm |
Yes I removed the old one. Good job I didn't drain the oil first. I found that the one that was sent to me did not clip in, and had a raised lip around the hole and was longer. |
16th May 2023 4:13pm |
OK so the only way to be sure is to buy a geniune one from Duckworths here and compare or even ask there advice , they are helpfully to us members. overfinch modified |
16th May 2023 7:31pm |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Amazon Mann HU 718/5X is the best filter you can buy for the 4.4 SDV8. It says pack size 2 but you only get 1. |
18th May 2023 6:07pm |
Reading what Suki said about the oil filter I,m now wondering why the one I posted above did not fit as it's the same part number .
18th May 2023 6:33pm |
I would say much stronger than Genuine the cords that go around the filter stop the filter from deforming keeping the oil path fully open. |
18th May 2023 7:33pm |
OK all, I have found the answer to my dilemma.
21st May 2023 12:48pm |
21st May 2023 12:49pm |
Thanks Suki I was worried a bit there but glad to see they all fit. overfinch modified |
21st May 2023 4:29pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3652 |
I know this is an old thread but I just got supplied a OX153 D3 will it do or should I send it back and get a D2 ? Geoff |
12th Sep 2023 1:11pm |
