Home > Maintenance & Mods (L322) > 4.4 TDV8 Serpentine (Accessory) belt length?
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hello All,
Via an online car parts webshop I got 50% discount on 2 brand serpentine belts.
Continental and SKF.
Point it, the length they spec isn't the same.
They BOTH cross reference to LR022803, so that checks out.
The Continental is 2523mm and the SKF is 2518mm.
Sure, that's only 5mm difference, just about 0.2%.
Does anyone know the OEM LR022803 length?
Thanks in advance Thumbs Up 2012 4.4TDV8
2000 Honda S2000
Post #663186 1st May 2023 12:54pm
dingg1
Just buy the cheaper one, 0.2% tolerance will not make any difference....
Post #663187 1st May 2023 12:59pm
fmgl322
Germany
Hi Spitfire! As I'm also based in Germany, I'd like to take advantage of that offer too - please send details if possible - gerne per DM!
Danke!
FMG -------------------------
2012 4.4 TDV8 Vogue
2001 Audi A2 1.4 16V
2019 Skoda Kodiaq (don't ask...)
Post #663188 1st May 2023 1:01pm
SpitfireS
I was thinking someone would post the original length is 2520mm Laughing
Yeah, I know, 5mm on 2523/2518mm is nothing, divided by 2 = 2,5mm on the tensioner.
But still... Wink
The webshop is KFZTeile24.de (you need an account)
It could be I got the discount via Payback.
A search for LR022803 gives more hits, those 2 were the brands I know.
Any experience with either brand belt?
Or is OEM the only way to go?
Who makes the OEM belt?
Smile 2012 4.4TDV8
2000 Honda S2000
Post #663190 1st May 2023 1:14pm
SpitfireS
As if it knew...
Before starting this afternoon I thought to check for the white markings on the belt I saw the other day.
You know, one might be lucky.
The OEM Landrover belt is 2518mm.
Mine also looks to have more wear - if you could call it that - at the front.
Maybe this has to do with the chirp at cold starts (that's why I started it) even with a new tensioner.
Smile 2012 4.4TDV8
2000 Honda S2000
Post #663202 1st May 2023 3:55pm
SpitfireS
Here they are.
The SKF is slightly narrower with 21,3mm, the OEM is 22mm.
I'm not finished replacing the idler before the alternator (in the belt travel direction) so I can't tell 100% it's going to work yet.
That idler was the cause of the chirp at the alternator pulley, I think, the old belt had some wear at the edge as the idler was not aligned with the alternator pulley anymore.
Smile
Edit 21-05-2023
The SKF works like a charm, no more chirps. 2012 4.4TDV8
2000 Honda S2000
Post #664471 19th May 2023 10:30am
