Home > Technical (L405) > Dumb question
AnnualMan
Switzerland
Dumb question
OK so I'm going to ask....
What's the impact of having worn lower suspension arms? What benefit would you feel having them replaced? 2025 P550e AB
Post #664481 19th May 2023 12:29pm
Gremlin500
Not a daft question at all…..
It’s the rubber bushes that wear and allow more play in the joints, allowing an amount of vagueness to creep into the handling and composure and steering of the vehicle.
Replacing them returns the car to a sharper feel of handling.
If left too long, you will get knocking and thumping eventually, and of course, its an MOT fail, so if you have an advisory, its better to get them changed before the next MOT.
Most people seem to just change the whole arm rather than mess about with a press and change just the bushes. I ‘ve not done it myself, but will be this Summer, so I’d be interested to see how you get on. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #664494 19th May 2023 1:31pm
AnnualMan
Switzerland
Thanks very much for the info!
So it’s a bit more sharpness to the steering and a tauter ride…..good to know! 2025 P550e AB
Post #664495 19th May 2023 1:35pm
It will also wear your tyres out unevenly and effects braking and steering so if they are showing signs of wear it's false economy to leave them....
I changed just the bushes on my first 322 (similar arms) and I'd never do it again... it's just not worth it especially if your paying for labour... Thumbs Up Pete
-Click here for Thread-
Post #664496 19th May 2023 1:40pm
AnnualMan
Switzerland
I had mine replaced entirely and I now the car feels like it leans and wallows less. I just wanted to double check it wasn’t bias on my part or my imagination, especially as the difference is fairly subtle (it’s not exactly turned in to a GT3 RS) 2025 P550e AB
Post #664497 19th May 2023 1:44pm
Gremlin500
Did you get a wheel alignment done, and is it really neccessary?
My thoughts are that it shouldn’t be because there’s no adjustment to it?
I’m doing mine this Summer, so just wanted to be sure I do it properly…. V6 Vogue - “Less is More” - less to go wrong!
Post #664535 20th May 2023 8:36am
AnnualMan
Switzerland
The mechanic did a test drive for 10 min and concluded no alignment was necessary. Was offered to me regardless if I felt strongly one way or another but for £150 + VAT I thought I’d trust the mechanic! So far the car feels fine 2025 P550e AB
Post #664541 20th May 2023 11:08am
