Home > Technical (L405) > Ride quality -16 SDV8 AB |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Was the 12v readings previously when the engine was running?
15th May 2023 9:02am |
If you haven’t done so already, I’d suggest keeping that voltage screen open when driving and noting the voltage when the steering is heavy vs normal.
15th May 2023 10:50am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1243 |
15th May 2023 11:47am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 593 |
Thanks for the very informative post Fisha.
15th May 2023 1:08pm |
No idea. I did notice as wel that when you go faster and above 60 , the default value begins to drop down to 1.3-1.4. So it must be firming up as the speed increases to improve handling. V8 or else ... |
15th May 2023 1:14pm |
Having a new tyre fitted on the n/s/r on Friday to replace the one which can't be brought any lower than 110 newton's on the road force.
15th May 2023 10:42pm |
Just had a feel of the steering in my sisters Velar R dynamic SE (D180 diesel) only whilst sitting on her drive but I found I could dry steer that with 1 finger, no resistance at all!
16th May 2023 5:18pm |
The tech will be similar, but the force programming might not be. I.e. the firmware of the L405 may be programmed to be stiffer than the Velar. Been a while since I last drove the evoque, but it was definitely lighter in feel, yet has the same tech as the L405. IIRC i remember the L322 being lighter than the L405 as well. The L322 had a lighter, smoother, yet more connected feel. It also had speed sensitive power assist, which I dont remember the reading the L405 having in the same manner.
16th May 2023 8:43pm |
You see I don't understand why that would be, I would expect the top of the line model to be better...
16th May 2023 9:06pm |
I wonder ... if it could be related to the torque sensor on the rack. Really long shot stuff now.
17th May 2023 12:57am |
I dont know Fisha, it could be but I would of thought I'd get a fault unless it's just designed like that.
17th May 2023 9:05pm |
For those who said alignment earlier in the thread, it's been checked today on hunter hawkeye, slightly out so adjusted to be correct and it makes no difference. |
19th May 2023 2:45pm |
Is there any way to completely remove and reflash the firmware in all the modules?
20th May 2023 9:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
I don't think that will do anything, if the modules were learning ones then they would have already learnt where they need to be, so no difference from resetting them and having them learn where they should be, a bit like going to the same location, but from a different start point...
20th May 2023 11:18am |
