Home > Technical (L322) > no low range TD6
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Thanks Phil for the info re plug and play.
I'll shall do as instructed when I replace it.
Further research I did last night I found a transmission company in Australia that has the New Venture Transfer Case " alltranz.com.au". I have sent them an email to see if they have just the actuator for sale,as they list that as a "part". Was thinking if I do get it,I'll put it into my Censored one and see if that will work it.
Thanks for your help and wisdom,very much appreciated.
cheers
littlecub
Post #664564 20th May 2023 11:04pm
littlecub
RRPhil,
Your advise please.
My new 2nd hand NV225 turned up today.
Got car up on ramps so I could have a look and got the old one off.
The teeth for part to go onto dont match where the teeth are on new one.
"Powerful UK" has a video where you turn the clockwise so that it will match the part you are putting in.
I think my old one is aligned to "low" and the new one is aligned to "high".
How do I get the teeth aligned up please......
a) turn the cog from the main body out so it aligns up
b) turn the cog on the new part--how can I do that as I dont have a tool big enough that will turn the cog. Did think of putting electric connector on it and using "37" fuse to see of that would make a difference.
Sorry if I am hassling you,but your knowledge is greatly appreciated within the RR community.
Thanks once again.
littlecub
Post #664654 22nd May 2023 5:57am
RRPhil
It’s most likely to be easier to power the motor to turn it, to get the missing tooth aligned.
You could turn the lead screw but a) this only works in one direction, otherwise it just unscrews itself out of the casing b) you would probably have to have the wheels off the ground to relieve the load on the teeth.
(Note that these photos were taken on a workbench so the orientation of vertical/horizontal is not exactly the same as on the vehicle)
Lead Screw
Phil
Post #664684 22nd May 2023 12:35pm
p38arover
Australia
"(Note that these photos were taken on a workbench so the orientation of vertical/horizontal is not exactly the same as on the vehicle)"
Photos upside down? Is that the fill plug hole? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #664745 23rd May 2023 7:19am
RRPhil
I would say that the photos require rotating anti-clockwise about 30 degrees to have the same vertical alignment as the transfer box installation in the vehicle. It looks to me like the motor axis is about horizontal.
Phil
Post #664810 23rd May 2023 6:52pm
littlecub
Well I took newish potentiometer out of newer transfer mtoor and put it into my old transfer motor.
Put it all back together and it didnt make a jot of difference.
Still stuck in low Censored Big Cry
To RRPhil, did try your suggestion of putting fuse in"37" and tried that recalibration as well..No luck.
Seriously considering getting rid of the beast now cause I cant afford $2G plus for another transfer box.
Any suggestions greatly appreciated.
littlecub
Post #664849 24th May 2023 4:19am
RRPhil
I understand your frustration but would urge you not to give up just yet.
In my opinion, you still need to establish if the fault is caused by a non-functioning shift motor or if the issue lies within the transfer box itself.
Have you seen/heard any indication that power is getting to the shift motor and that it is turning? Did you swap the potentiometer rather than try to re-align the spline by applying 12v to the shift motor? I think that you need to try powering the shift motor, on the bench, to check that it is functioning and, if so, then try to establish why it isn’t receiving the necessary electrical input from the vehicle (e.g. an issue with ECU, wiring, switch, connector, etc.). If this is the issue, swapping transfer boxes will not fix this, as stuart_2006 has already stated.
Phil
Post #664967 24th May 2023 10:43pm
littlecub
Question......
Did you disconnect the battery to take off/on the TM as I havent.
Just wondering whether that would make any difference.
Thanks.
littlecub
Post #665003 25th May 2023 10:34am
p38arover
Australia
I didn't disconnect the battery when removing the shift motor. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #665084 26th May 2023 3:05am
littlecub
Hi Ron,
Did you have it in high or low when you took it off.
Also I sent you a PM on AULRO.
littlecub
Post #665086 26th May 2023 5:22am
p38arover
Australia
It was in high range when I removed it. I used my local LR indie's hoist when it was free one weekend. Much easier than laying on one's back.
Re the PM on AULRO, I asnwered it in the thread but to reiterate, the potentiometer cover came off relatively easliy. It was over a year ago so I can't really recall how I did it. I thought I might have posted on FullFatRR but I can't find it. I'll search again. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #665090 26th May 2023 7:21am
littlecub
Fixed
Well I pulled the old TM back off and transferred the newer poteniometer from the old TM to the newer TM as I got
the electrics working to bring the cogs around to where it would fit into the TC as I hadnt been able to do that before.
As I had pulled the old one off/on a few times I got a LTR of the BOT 26 delivered from LR.
The transfer oil was a little suspect..it was a bit greyish. Left to drain for an hour or so while I had bite to eat.
Put newer TM back on,then oil in and hoped for the best.
This morning I fired up the beast after checking that I had no leaks anywhere(did that as well yesterday),
gave the switch a gentle tug and I though I heard a very slight clunk( have had NO low range symbol on dash after rear end was hit by a truck 8 years ago,altho it comes on when i put it into sport lol).
Put it into R and reversed off the ramps and its definitely in high range.
Thanks to RRPhil for his helpful hints. Bow down
cheers
littlecub
Post #665430 29th May 2023 10:04pm
Well done, and not too expensive... Thumbs Up Pete
Post #665434 29th May 2023 10:51pm
