Home > Maintenance & Mods (L322) > RR 4.4tdv8 2011 Engine oil
Fatbear
Has anyone on the forum used Smith and Allen Oils, they have a fantastic reputation
They sell the below specification oil and they are a the biggest independent U.K. manufacturer of oils and have been going for 80 years and 20 litres of their oil is £75.95 inc delivery
5W-30 Fully Synthetic Engine Oil ACEA C1 Low SAPS Ford WSS-M2C934-B 20 Litre 20L
Post #664750 23rd May 2023 8:15am
DrRob
Lots have. If you use the "Search" function in the banner above it will show all posts relating to it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #664751 23rd May 2023 8:16am
Fatbear
Thank you 🙏 for your quick reply hopefully I’ll get used to the forum quickly, please can I ask you IYO what are good discs and pads to buy for my Rangy
Post #664753 23rd May 2023 8:21am
Baltic Blue
Contact Rob at Duckworths, he will do you a good deal on genuine parts and you can’t go wrong.
Post #664763 23rd May 2023 9:26am
JayGee
OE disks are not too expensive if you shop around ( they are made by Brembo). OE pads are not such a good deal so take your pick from one of the major brands. Be aware that the rear callipers are prone to seizure of the piston in the bore so may need replacing and the front callipers are alloy which often results in the seizure of the pins and bleed nipples from galvanic corrosion which can turn a simple job into something very serious and expensive. Plenty of info on here and on youtube eg
 2012 TDV8 Vogue (L322)
Post #664764 23rd May 2023 9:30am
DrRob
Not Meyle or was it Delphi?? Need to check. They warped and caused wheel wobble on braking. Now on Borg and Beck. Much better Bow down
I get 99% of my parts from site sponsor Advanced Factors with the forum code "AF4LRP" Thumbs Up
https://www.advancedfactors.co.uk/brake-parts-51-c.asp
I got their front kit with pads and discs Thumbs Up
https://www.advancedfactors.co.uk/kit234b-...4904-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664769 23rd May 2023 11:52am
DrRob
Just replaced my rear calipers as they looked very old, rusty and grotty.
https://www.advancedfactors.co.uk/rear-bra...-175-c.asp
#preventative_maintenance is my mantra Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664771 23rd May 2023 11:56am
garyRR
If you keep an eye on AutoDoc, the OEM TRW calipers are often on offer at c.£80 each. I too have replaced both my rear calipers by way of precaution. 2015 Range Rover Autobiography 4.4 SDV8
Post #664862 24th May 2023 8:50am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
On the website of Smith and Allan one can download the SDS of the Momentum C1 F 5W-30.
This document shows (Section 3: Composition) it's a blend of synthetic and highly refined mineral oils where the percentage of the mineral oil is between 10-25%.
Mineral oils are used in full synthetics to dissolve additives but, AFAIK, never above 3% or so.
Highly refined mineral oils could be hydrocracked mineral oils and they are claimed to be synthetic but by definition they are not.
To call the Momentum C1 a full synthetic is, imo, a bit overstated.
Doesn't mean it's bad oil. 2012 4.4TDV8
2000 Honda S2000
Post #664896 24th May 2023 12:06pm
JayGee
Hardly any oils are fully synthetic and the ones that are are obvious from the price. For a diesel application you want good soot holding capacity and these low revving engines don't require the kind of high load /high rpm / high temp protection that fully synthetics's offer. 2012 TDV8 Vogue (L322)
Post #664901 24th May 2023 12:17pm
SpitfireS
The oil pressure in a crank / connecting rod journal is produced by rotating.
As the TDV8 produces high torque at low rpm the oil film has to deal with this (=keeping parts apart) at low rpm so oil film strength is a factor.
To think a low revving V8 doesn't need good oil is a mistake, imo.
Smith And Allan don't specify the HTHS (High Temp High Shear) of their oil, unfortunately.
The other numbers are normal.
It's Smith and Allan that call their C1 oil fully synthetic on their website and it's not just imo that it's not: they say (admit?) so in their SDS. 2012 4.4TDV8
2000 Honda S2000
Post #664903 24th May 2023 12:43pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Very expensive caliper prices there I'd say. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #665009 25th May 2023 12:01pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Westway Oils - made in the UK, been going for years, great prices and free next day delivery. Check them out…
https://www.westwayoils.co.uk/collections/...0702420108 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #665448 30th May 2023 7:40am
Ajmngn
They also do oils for transfer box, diff, ZF6 and ZF8 gearboxes, brake and power steering fluid. Not sure if I’ve missed any but it’s all there on the website, all within specs. 👍 Andy
Post #665449 30th May 2023 7:45am
DrRob
Offset by their customer service for me. I had some brake discs warp and they swapped them out for new ones (different brand) after 12 months. No quibbles. Not many places would do that. Plus we get a bit of discount and the calipers are TRW which are OEM Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665451 30th May 2023 8:15am
