![]() | Home > Maintenance & Mods (L322) > RR 4.4tdv8 2011 Engine oil |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Lots have. If you use the "Search" function in the banner above it will show all posts relating to it |
Fatbear Member Since: 23 May 2023 Location: Nene Valley Posts: 18 ![]() ![]() |
Thank you 🙏 for your quick reply hopefully I’ll get used to the forum quickly, please can I ask you IYO what are good discs and pads to buy for my Rangy |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
Contact Rob at Duckworths, he will do you a good deal on genuine parts and you can’t go wrong.
OE disks are not too expensive if you shop around ( they are made by Brembo). OE pads are not such a good deal so take your pick from one of the major brands. Be aware that the rear callipers are prone to seizure of the piston in the bore so may need replacing and the front callipers are alloy which often results in the seizure of the pins and bleed nipples from galvanic corrosion which can turn a simple job into something very serious and expensive. Plenty of info on here and on youtube eg
Not Meyle or was it Delphi?? Need to check. They warped and caused wheel wobble on braking. Now on Borg and Beck. Much better ![]() I get 99% of my parts from site sponsor Advanced Factors with the forum code "AF4LRP" ![]() https://www.advancedfactors.co.uk/brake-parts-51-c.asp I got their front kit with pads and discs ![]() https://www.advancedfactors.co.uk/kit234b-...4904-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Just replaced my rear calipers as they looked very old, rusty and grotty. https://www.advancedfactors.co.uk/rear-bra...-175-c.asp #preventative_maintenance is my mantra ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
If you keep an eye on AutoDoc, the OEM TRW calipers are often on offer at c.£80 each. I too have replaced both my rear calipers by way of precaution. 2015 Range Rover Autobiography 4.4 SDV8 |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
On the website of Smith and Allan one can download the SDS of the Momentum C1 F 5W-30.
Hardly any oils are fully synthetic and the ones that are are obvious from the price. For a diesel application you want good soot holding capacity and these low revving engines don't require the kind of high load /high rpm / high temp protection that fully synthetics's offer. 2012 TDV8 Vogue (L322) |
The oil pressure in a crank / connecting rod journal is produced by rotating.
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140 ![]() ![]() ![]() |
Very expensive caliper prices there I'd say. Cam 2011 TDV8 Vogue in Stornoway Grey |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
Westway Oils - made in the UK, been going for years, great prices and free next day delivery. Check them out…
They also do oils for transfer box, diff, ZF6 and ZF8 gearboxes, brake and power steering fluid. Not sure if I’ve missed any but it’s all there on the website, all within specs. 👍 Andy
Offset by their customer service for me. I had some brake discs warp and they swapped them out for new ones (different brand) after 12 months. No quibbles. Not many places would do that. Plus we get a bit of discount and the calipers are TRW which are OEM ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
