Home > In Car Electronics (L322) > Radio again!!!
William97841
When you say hard reset do you mean disconnect the battery and touch the positive and negative together?
Post #666199 8th Jun 2023 7:55pm
DaveAbbott
Hard reset , is the equivalent of switxhing off your computer and re booting it.
So Let the car stand for an hour or so, with No kery in it
Disconnect the battery, negative first , then positive Leave for a couple of hours
Touch the pos & neg leads together and reconnect , negative first.
Re start the motor and turn full lock left and right
That worked for me.
I discovered that the RR infotainment system has a " transport" mode which is what causes it to switch on and off.
The hard reset cured it for me.
Dave
Post #666203 8th Jun 2023 9:26pm
William97841
So tried that last night even put my battery on charge over night touched this morning and reconnected still a black screen and flashing amber light sadly hasn’t done but I shall try more things lol
Post #666300 10th Jun 2023 8:34am
William97841
Solved!!!!!
Finally fixed the radio but sadly have lost traffic system TA alerts but not worried about that. Lost the iPod connection which was never used as didn’t work right. But now working radio. So basically the blue wire that feeds the radio was giving 0.34 volts so it was broken. Rerouted a new cable and a second fused adapter cable off fuse 49 (dual fused lead) And ran it to the radio. Don’t know how it happened but finally fixed yay. 😀
Post #669712 24th Jul 2023 3:16pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
well done Thumbs Up
Post #669741 24th Jul 2023 9:02pm
