Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 18 of 35 <123 ... 171819 ... 333435>
MarianaWestminster
I'm communicating with Sam at the moment Knwatkins. He hasn't made further progress but does have some more things to try.
I've also posted in his thread about it.
The thing is his only issue is the ride, he doesn't have issues with the steering and engine lag like I also do.
So it may or may not be connected.
Post #666346 11th Jun 2023 9:56am
MarianaWestminster
Well I'm in the doghouse...
Me and my partner have been discussing a Continental road trip since last year.
Shes been asking and I've just had to break the news that I will not be entertaining doing it in the L405.
I can barely tolerate driving it to work let alone thousands of miles across France, Germany and Italy.
Post #666425 12th Jun 2023 12:23pm
caymanblack
Mariana i think it's time you changed it! Is it worth the hassle? overfinch modified
Post #666440 12th Jun 2023 3:04pm
Merchy
Sorry to read that about the road trip. If the relationship with your car is starting to affect the relationship with a good partner, then it is definitely time to get rid of the car.
Post #666442 12th Jun 2023 3:27pm
Martin2
I agree with the suggestions to let it go, I can't see you ever getting it drive as you want it to and as time goes on it's just going to annoy you more and more. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #666443 12th Jun 2023 3:55pm
MarianaWestminster
I don't feel I can sell it just yet as I only purchased it recently and the drive home was great. Was it just the new car thing pulling the wool?
I dont understand how everybody else can be so happy and yet me so unhappy.
I've always wanted an L405 since they launched in 2012 and I honestly thought it would address the issues I had with my 2 facelift l322s.
I keep looking at big German saloons but I've always had British as a daily driver and they just don't appeal in the same way.
The other option is to go back to a 06-09 l322 as I was so happy with my Westminster.
I'm going to find another one like mine to drive so I can do a mental comparison between it, my own and Haylands one that I drove.
Post #666448 12th Jun 2023 5:26pm
caymanblack
Ok go to the dealer and inquire about a change and get a test drive you never know perhaps you can get a good deal Laughing but for sure you can get a test drive. overfinch modified
Post #666454 12th Jun 2023 7:42pm
MarianaWestminster
Thing is the 2 local dealers only seem to stock facelift 2018 onwards cars.
Do these have the same suspension or are they revised?
I need another fair comparison but it's always in the back of my mind that Haylands thought mine was OK and I thought his was OK when I drove it.
But sometimes when I'm driving mine I'm like 'surely that can't be right'
'Surely the buyer of this car new wouldn't have accepted that'
Etc
Post #666461 12th Jun 2023 8:00pm
MarianaWestminster
Something else I've noticed, it still takes quite a while to lift the air suspension.
From access to normal with the engine running takes 32 seconds (watching the 4x4i screen with the stopwatch on my phone)
This was tested after just having arrived at work.
Post #666491 13th Jun 2023 7:42am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Could one of the air suspension valve blocks be at fault ? Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #666502 13th Jun 2023 10:37am
GraemeS
Australia
Have the CVD lives values been graphed while moving? Familiarising myself prior to assisting a Defender owner with a harsh ride, I checked the accelerometer voltages while stationary then over some ruts to see that all 3 varied up and down but quickly settled back to their stationary values once stopped. I then graphed the various values of the shocks, noting that the best general indicator was the current that was mostly at maximum, occasionally less over bumps then back to zero once stopped. The other attributes changed very quickly over bumps, ruts and side-slopes showing that the system was reacting to the varying conditions but impossible to know to what extent, whereas the current graph showed that the bypass valves were for most of the time meant to be fully open to provide a soft ride. However I don't know if its possible to identify faulty or worn-out shocks/valves from the shock graphs although combining height sensors might help. The terrain was quite rough in spots and travel speed around 30 kph. My IIDTool wouldn't save the graphs due to a bug.
Post #666504 13th Jun 2023 10:55am
I don't want to be the bearer of bad news but you have issues sir.....
Engine running....
Access height to normal height...
Normal height to off road height...
I think you need some in depth diagnostics doing..... Thumbs Up Pete
Post #666505 13th Jun 2023 10:58am
MarianaWestminster
Thanks Haylands,
So it seems I've actually found something out of spec Laughing
Here's a YouTube video of a graph via IID tool.
The vehicle has been driven at normal height for approximately 30 minutes so plenty of time for the air reservoir to be fully filled in anticipation of a lift.
Front left height sensor voltage at 2.72 volts is access height.
When it reaches 2.13v stable the display in the car shows normal height has been achieved.
Any thoughts? Any possibility you can compare Pete?
I see the car is running the compressor during the lift, I don't know if that's to aid lifting or to begin replenishing the air reservoir from the moment the lift is requested ?
Post #666540 13th Jun 2023 8:30pm
MarianaWestminster
Helps if I actually post the link to the video..
Post #666541 13th Jun 2023 8:31pm
GraemeS
Australia
If you're concerned that the sensor voltage reduces as height increases then don't be, as 2 sensors increase while the other 2 decrease as height increases. Also don't try to compare with a L322 as their arrangement is different.
Post #666552 13th Jun 2023 10:35pm
