![]() | Home > Maintenance & Mods (L322) > Connector to charge via towing socket, not CTEK |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Just make one up …buy the trailer end of the socket that plugs into your FF then wire up the live terminal and the earth, there are lots of wiring diagrams to show which should be the permanent live on your car. I presume you have a 13 pin socket? Then other ends onto a block of would clearly marking which is positive and which is negative so you can connect your crocodile clips. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Britpart have them iirc
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Greg,
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
Thanks for that @Mike; I was wondering if that worked on the 4.4 because of the battery management system. On mine I’m planning to route the CTEK connector externally so that I can charge/recover the battery if it runs too flat to unlock.
Earth connection is easy to a convenient 10mm nut/ stud , perfect for the 6mm eyelet.
