Home > Maintenance & Mods (L322) > Connector to charge via towing socket, not CTEK
GGDR
Hello team
I can't find those charger things that used to be for sale,
could anyone point me in the right direction?
Also I don't yet have a CTEK, just a crappy but never-let-me-down slow charger with alligator clips so ideally I could connect that up...
. Cheers, Greg
Post #666481 12th Jun 2023 11:29pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Just make one up …buy the trailer end of the socket that plugs into your FF then wire up the live terminal and the earth, there are lots of wiring diagrams to show which should be the permanent live on your car. I presume you have a 13 pin socket? Then other ends onto a block of would clearly marking which is positive and which is negative so you can connect your crocodile clips. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #666485 13th Jun 2023 12:11am
DrRob
Britpart have them iirc
Paddocks Spares should stock them Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666497 13th Jun 2023 8:54am
Baltic Blue
Greg,
I have found my permanently wired CTEK socket to the rear fusebox to be just as handy to use and a cheaper solution.
Just buy a CTEK socket to 6mm eyelets lead and extend it if you want to plug the charger in outside the car.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #666498 13th Jun 2023 9:10am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Thanks for that @Mike; I was wondering if that worked on the 4.4 because of the battery management system. On mine I’m planning to route the CTEK connector externally so that I can charge/recover the battery if it runs too flat to unlock.
I’m guessing there’s an earth post just to the right of the fuse board adjacent to the rear lights? TDV8 4.4 2012
Post #666509 13th Jun 2023 12:54pm
Baltic Blue
Earth connection is easy to a convenient 10mm nut/ stud , perfect for the 6mm eyelet.
Post #666510 13th Jun 2023 1:27pm
