Home > Maintenance & Mods (L322) > How to check DPF status with IIDTool |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 326 |
I've no reason to suspect I've an issue, but I was curious about the status of the DPF as I've never seen a warning about it in the ~2 years I've owned the car...
19th Jun 2023 9:57pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
It is a gigantic topic. This post will give you a solid understanding although if you don't have an issue, I would not bother!
19th Jun 2023 11:52pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4236 |
As above, no amber or red light then don't go down the rabbit hole
20th Jun 2023 7:28am |
I'm getting *very* strong, "if it ain't broke, don't try to fix it" vibes and you guys are usually right so...
20th Jun 2023 7:31am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2701 |
The DPF is self cleaning so it's not at all like an oil or air filter. 2012 TDV8 Vogue (L322) |
20th Jun 2023 10:15am |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 82 |
Well... yes, but actually no. The regeneration cycle turns the soot into ash, so yes it removes the soot. The ash stays in the filter though, no on-board regeneration is able to remove the ash. Lets say, for arguments sake, the ratio of soot to ash is 100:1 A 100% full-with-soot DPF will turn into a 1% full-with-ash DPF. This means the DPF can hold only 99% soot. During the next regeneration this 99% soot is turned into 1% ash again. Now the DPF has 2% ash and can hold 98% soot. And so on and so on and so on... At some point the DPF will be full enough with ash for the ECU to say "It's done" And then it gets expensive. 2012 4.4TDV8 2000 Honda S2000 |
20th Jun 2023 1:12pm |
Agreed but only if you get an amber or red warning should you worry. Otherwise, drive it and enjoy it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
20th Jun 2023 2:12pm |
And then just cut it out, blank and map out the EGR. Then, remap it and move on Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
20th Jun 2023 2:13pm |
That will be at very high miles unless you have another fault so again it's nothing like an air or oil filter. It's more like any other component which will wear out in time such as a gearbox or shock absorber or wheel bearing.... 2012 TDV8 Vogue (L322) |
20th Jun 2023 6:27pm |
until the MOT inspector fails it. 2012 TDV8 Vogue (L322) |
20th Jun 2023 6:28pm |
Imho: no. Besides, what's high miles in your opinion? When you drive 120.000km with a DPF it will fill up with ash and there is no other fault needed for this to happen. And one can be sure it will happen earlier if you drive only short distances and/or city miles. If one plans to keep the car for a while, cleaning the DPF off-board, so to speak, is IMO part of routine maintenance. It's what you get driving a car with a DPF, it's something they don't mention when you buy the car. That this is a 4 year routine - in my case - doesn't mean it's not a routine. And I don't plan to change my gearbox ever, to be honest. Especially not after having it flushed at 130.000, also something Landrover doesn't mention but ZF does recommend. The air (front) springs probably need replacing in 10 years (as mentioned by many on this forum) or maybe wheel bearings if an alignment shows they are done. AFAIK my 11 year 215000km old shock absorbers are fine. 2012 4.4TDV8 2000 Honda S2000 |
21st Jun 2023 2:48pm |
You sound like that guy that jumped out of a 50 story building. People could hear him say at floor 15, as he rushed by: "So far so good!" Passing floor 5 he got the amber warning Passing floor 3 he got a red warning Time to open the parachute, right? 2012 4.4TDV8 2000 Honda S2000 |
21st Jun 2023 2:52pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
I know a guy with 350,000miles on the 4.4 diesel, he's never had to replace the DPF but he has had a new gearbox and several sets of shocks, among other things... maybe it's the way he drives... Pete
21st Jun 2023 6:22pm |
